iLogic Try, Catch, Error... ?
Basically, I'm trying to assign an appearance to a face.
1. Try: Assign appearance to face
2. Catch (if the appearance isn't in the current doc)
Try to bring it in from a library
3. ????? (what if the appearance isn't found in a library) <<< Is this going to be another "Catch" line????
Show message "Can't be found"
Or perhaps, I need to us "On Error"?
Thanks.
tdant
You can use multiple Catches in a Try statement, using either an error type or When statement to qualify the Catches.
Try [GetApperance]
Catch ex1 When IsError([GetAppearance])
     ' error handler for ex1
Catch ex2
     ' error handler for ex2
End Try
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to assign a color to face.
 Dim oPartDoc As PartDocument
	oPartDoc = ThisApplication.ActiveDocument
	Dim oFace As Face
	oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a face")
	'define the appearance library
	Dim oLib As AssetLibrary
	oLib = ThisApplication.AssetLibraries("Autodesk Appearance Library")
	'make sure colors are in assembly doc
	Dim libAsset As Asset
	libAsset = oLib.AppearanceAssets.Item("Steel")
	Dim localAsset As Asset
	Try
		localAsset = oPartDoc.Assets.Item("Steel")
	Catch
		localAsset = libAsset.CopyTo(oPartDoc)
	End Try
	oFace.Appearance = localAsset
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
