I need to add a condition to my form...?
chris
Advisor Advisor
chris
I have a few options to choose from for a part I am making, but to cut down on the confusion when changing this part I wanted to add in some conditions to the form to limit changes.
Example:
There is a tubing Type to choose from, when Square_Rect is chose I'd like the "Tubing_Round_Size to be "grayed out", likewise, when the Tubing_Type "Round" is chosen, I'd like the (Tubing_Square_Rect_Size) box options to be grayed out.
I have this working for the "Corner_Type", but between corner type and corner cut it's either true or false... not sire how to make this work for two options, based on which option is chosen.Options.PNGOptions2.PNG
bradeneuropeArthur
For ilogic or vba or vb.net?
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
chandra.shekar.g
Autodesk Support
Autodesk Support
@chris,
This can be achieved by creating Boolean parameter in the document and control this parameter based on the value of "Tubing_Type" by enabling parameter name.
If tubing Type is choose as "Square_Rect", then value of Boolean parameter is "false" which disables or grey out the "Tubing_Round_Size" parameter and vice versa.
For more details, refer below blog link
https://www.cadlinecommunity.co.uk/hc/en-us/articles/211696909-Inventor-iLogic-form-behaviour-Enabli...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
