ilogic to vb.net help
Message 1 of 12
looking for a bit of help folks in translating a piece of illogic to vb.net.
I'm sure this is relatively easy for most, but I'm going round in circles.. The code is to look up an excel column (A) and find a string (textbox1.text) and then once found, write data to that row.
I have something that is working - sort of - but seems to take longer than illogic.
can anyone help in translating the code below?
any thanks in advance guys for any help with this
'Define the first row with data
RowStart = 7
'Define the amount of skipped rows
RowEnd = 1000
'Find the first empty cell
For countA = RowStart To (RowEnd * 0.01) + RowStart
'If it's not blank jump to cell + 1000. E.g. search cell A2 and then A102 etc.
If Not String.IsNullOrEmpty(GoExcel.CellValue("A" & RowEnd)) Then
'Add another 100 to searched cells
RowEnd = RowEnd + 1000
Else
'Else if it's empty exit loop
Exit For
Next
'Search for the file name in column A
For oRow = RowStart To RowEnd
If (GoExcel.CellValue("A" & oRow)) = oDocNumber Then
GoExcel.CellValue("C" & oRow) = DateString
Replies (11)
Message 2 of 12
frederic.vandenplas
I did not tested it, but it will point you in the right direction.
Do not forget to add a reference to the Microsoft Excel XX.0 Object Library (COM)
For Excel 2007 it's located here:
C:\windows\assembly\GAC\Microsoft.Office.Interop.Excel\12.0.0.0__71e9bce111e9429c\Microsoft.Office.Interop.Excel.dll
Imports Microsoft.Office.Interop
Public Class Form1
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        Try
            Dim oExcelApp As Excel.Application = GetObject(, "Excel.Application")
            Dim oWorkbook As Excel.Workbook = oExcelApp.ActiveWorkbook
            Dim oSheet As Excel.Worksheet = oWorkbook.ActiveSheet
            Dim RowStart As Integer = 7
            Dim RowEnd As Integer = 1000
            Dim oDocNumber As Integer
                If Not String.IsNullOrEmpty(oSheet.Cells(1, RowEnd).text) Then
                Else
                    Exit For
            Next
                If oSheet.Cells(1, oRow) = oDocNumber Then
                    oSheet.Cells(3, oRow) = DateString
            Next oRow
        Catch ex As Exception
        End Try
    End Sub
End Class
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 3 of 12
Hi Frederic
many thanks for your reply. I couldn't get it to work unfortunately, but have an adaptation of the code that I am working on. While it finds the relevant row and updates the appropriate fields, the program takes 30 seconds to run before the user can continue...
Ilogic does this in a fraction of the time... I'm missing something, somewhere obviously.
Could you have a look and see if there is anything obvious?
many thanks!!
Private Sub Button7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button7.Click
Dim xlApp As Excel.Application
Dim xlWorkBook As Excel.Workbook
Dim xlWorkSheet As Excel.Worksheet
Dim RowStart As Integer = 1
Dim RowEnd As Integer = 500
Dim oRow As Integer
xlApp = New Excel.Application
xlApp.Visible = False
xlApp.DisplayAlerts = False
xlWorkBook = xlApp.Workbooks.Open(TextBox1.Text)
xlWorkSheet = xlWorkBook.Worksheets("Sheet1")
Try
Dim oSheet As Excel.Worksheet = xlWorkBook.ActiveSheet
RowEnd = RowEnd + 500
Else
Exit For
Next
'check if the cell value matches the search string.
If xlWorkSheet.Cells(oRow, 1).value = (TextBox2.Text) Then
TextBox12.Text = xlWorkSheet.Cells(oRow, 2).Value
TextBox7.Text = xlWorkSheet.Cells(oRow, 3).Value
Next 'oRow
End Try
Message 4 of 12
frederic.vandenplas
Can you provide the excel?
Message 5 of 12
File attached, it is only a temp file for testing with a handful of numbers.
thanks for any light you can shine on it 🙂
Message 6 of 12
MechMachineMan
Try this!
'Modified by MechMachineMan to include built in excel functions as the app actually gets connected to.
   Dim oRow As Integer
   Dim oAPopulatedCOLUMN As Integer
oAPopulatedCOLUMN = 1 'Set this value to correspond to a column that is full with data. This will be used to find the last row instantly. xlApp = New Excel.Application xlApp.Visible = False xlApp.DisplayAlerts = False
Try xlWorkBook = xlApp.Workbooks.Open(TextBox1.Text)
' The workbook will only work for sheet 1. alternative line for active sheet is below: ' xlWorksheet = xlWorkBook.ActiveSheet xlWorkSheet = xlWorkBook.Worksheets("Sheet1")
oRowEnd = xlWorksheet.Cells(xlWorksheet.Rows.Count, oAPopulatedCOLUMN).End(XlDirection.xlUp).Row For oRow = RowStart To RowEnd 'check if the cell value matches the search string. If xlWorkSheet.Cells(oRow, 1).value = (TextBox2.Text) Then TextBox12.Text = xlWorkSheet.Cells(oRow, 2).Value TextBox7.Text = xlWorkSheet.Cells(oRow, 3).Value End If Next 'oRow Catch
MsgBox("Error in excel features!")
End try
xlApp.Visible = True xlApp.DisplayAlerts = True
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 7 of 12
Cheers Justin,
one minor point is that I need to declare XLDirection
what should I declare it as?
Message 8 of 12
MechMachineMan
https://msdn.microsoft.com/en-us/library/office/ff820880.aspx
I'm assuming you must have your references added to the Miscroft.Excel in the project already?
You might be able to get away with using just xlUp and not needing the enumerator there.
Depending on the environment, sometimes it gets fussy without it, sometimes it gets fussy with it.
Justin K
Message 9 of 12
hi
yes I have Imports Excel = Microsoft.Office.Interop.Excel assigned
off home now, but will have a look later tonight
thanks !
Message 10 of 12
MechMachineMan
If nothing else, it should work without error if you use the constant value
rather than the name ( -4162 vs xlDirection.xlUp)
Justin K
Message 11 of 12
thanks for your help justin and Frederic
I got this to work last night but instead of trying to define a set of rows to search through and then adding a few more if the value isn't there etc, I decided to look for the last row used in the entire sheet, and then used that as the search range....
all works well and nice and quick too
cheers
Message 12 of 12
adam.nagy
Autodesk Support
Autodesk Support
Are you all set now? 🙂
If so could you mark the answers that helped you the most as a "Solution"?
You can mark multiple answers as well if needed.
Thank you,
Adam Nagy
Autodesk Platform Services
