iLogic to trigger BOM in assembly
berry.lejeune
berry.lejeune
Hello all,
In the process of facilitating and making sure I don't forget anything when making my models I need a code to trigger  "BOM" in an assembly.
When I hit the iTrigger button in my assembly, I'm already getting two forms to make the assembly but I have no idea how to let the "BOM" come out so I don't forget to select the correct materials and enter the descriptions
WCrihfield
Hi @berry.lejeune.  One fairly simple thing you could do is have a line of code in a rule that executes the command to show the assembly BOM dialog, like this:
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBillOfMaterialsCmd").Execute
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
