iLogic to place Thickness into form
GKPByDesign
GKPByDesign
I want to place the sheet thickness (main sheet thickness) in my form, but when I do this it is greyed out. Can someone help, I like to use the sheet metal thickness for all and any part, can someone help me create a rule to make this work, or to grab a custom parameter to fill in the " Thickness " value.
bradeneuropeArthur
Could you upload your code you have that far.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
GKPByDesign
I don't have any code, no idea how to code, I was hoping someone could help me. I somewhat understand the idea with make a separate parameter to shift the sheet metal rule, but I need a hand
bretrick30
The reason the Thickness parameter is greyed out (Read-Only) in your form is because it is driven by the sheet metal defaults.  It appears that even turning off the option to use thickness from rule in the sheet metal defaults doesn't change this.
To get around this and to have the ability to change the thickness in an iLogic Form, you will need to create a User Parameter (I called it "SheetThickness"), then create an iLogic rule and paste the code below.  Make sure you do not suppress the rule and it will run each time the parameter is changed and will change the Sheet Metal Thickness.
I don't know what units you use (I use inches), since the Inventor API uses centimeters I needed to convert my parameter from inches to centimeters.  That part of the code is in bold.  You can change that for whatever conversion you like.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
oSheetMetalCompDef = oPartDoc.ComponentDefinition
oSheetMetalCompDef.UseSheetMetalStyleThickness = False
Dim oThicknessParam As Parameter
oThicknessParam = oSheetMetalCompDef.Thickness
oThicknessParam.Value = SheetThickness * 2.54
oPartDoc.Update
GKPByDesign
That's what I have done, and this way I don't need ani logic rule, thanks for the help
chandra.shekar.g
Autodesk Support
Autodesk Support
@GKPByDesign ,
If question is answered, click "Accept solution" on respective post.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
dgreatice
Just create user parameter for drive thickness sheetmetal.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
