Ilogic to link sub components to BOM
mgw_ps
Message 1 of 1
mgw_ps
I had a code that linked BOM Item # and Qty to sub components in an assembly so i could detail parts and have a link to the item # and Qty. It worked fine in Inventor 2024 but now is not working since i upgraded to 2025. Can anyone see the issue in my logic?
doc = ThisDoc.Document
Dim oOccs As ComponentOccurrencesEnumerator
oOccs = ThisDoc.Document.componentDefinition.Occurrences.AllLeafOccurrences
Dim oOcc As ComponentOccurrence
For Each oOcc In oOccs
	Call oOcc.Definition.Document.ComponentDefinition.BOMQuantity.SetBaseQuantity _
	(BOMQuantityTypeEnum.kEachBOMQuantity)
Next
iLogicVb.UpdateWhenDone = True
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
Dim oParams As Parameters = oAssyDef.Parameters
Dim oUserParams As UserParameters = oParams.UserParameters
Dim ParameterChecker As Parameter
Try
ParameterChecker = oParams("NUM_OF_ASSYS")
Catch
ParameterChecker = oUserParams.AddByValue("NUM_OF_ASSYS", 1, "ul")
End Try
Dim num_assys As Integer
num_assys = Parameter("NUM_OF_ASSYS")
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMView.BOMRows
    'Set a reference to the primary ComponentDefinition of the row
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRow.ComponentDefinitions.Item(1)
    Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
    Dim CompFileNameOnly As String
    Dim index As Integer = CompFullDocumentName.LastIndexOf("\")
    CompFileNameOnly = CompFullDocumentName.Substring(index+1)
    Dim Itm As String
    Itm = oBOMRow.ItemNumber ()
        If iProperties.Value(CompFileNameOnly, "Project", "Engineer") <> Itm Then
        iProperties.Value(CompFileNameOnly, "Project", "Engineer") = Itm
        End If
    Dim Qty As String
    Qty = oBOMRow.TotalQuantity
	   If iProperties.Value(CompFileNameOnly, "Project", "Authority") = "" Then
        iProperties.Value(CompFileNameOnly, "Project", "Authority") = num_assys*ItemQty
        End If
        If iProperties.Value(CompFileNameOnly, "Project", "Authority") <> num_assys * ItemQty Then
        iProperties.Value(CompFileNameOnly, "Project", "Authority") = num_assys * ItemQty
        End If
Next
I have attached a screen shot of the error.
Replies (0)
