How to add a user parameter to all parts in an assembly for selecting a cutting list
ErikMebo
ErikMebo
Hi all,
I'm trying to add a boolean user parameter to all parts in an assembly at once to have a selection criteria for a cutting list. But can't find a way to push that to all parts in an assembly. It will enable me to select if an extrusion needs to be in that cutting list or not.
Am I missing something? Or will I have to do this manually?
jwingateRJECD
Instead of trying to add a user property to all of the parts in your assembly, I would suggest making two array lists: one of all of the different parts that can be considered parts that go on a cut list, and a second one that you would select the parts you want to go into. That array list can then be used to select parts for your cut list. If you are using members from the content center this is significantly easier since you can reference if the stock number iproperty is empty or not, and what the G_L or PL value is. I've attached what I use below, but it's just the first step really. I'm assuming you already have a plan for handling the cut list after this, hope it helps.
Imports System
AddReference "System.Drawing.dll"
Imports System.Windows.Forms
Imports Inventor
Public Class StockSelection
	Shared Dim oStockList As New ArrayList
	Shared Dim oChosenStockList As New ArrayList
	Shared Dim oText As String
	Shared Dim Y As Double = 0
	Public Sub Main()
		If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
			MessageBox.Show("This rule only works for assemblies.", "Wrong Document Type")
			Return
		Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
		Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
		Dim oSubADoc As AssemblyDocument
		Dim oSubADef As AssemblyComponentDefinition
		oStockList.Clear
		oChosenStockList.Clear
		'Dim oOccs As oADoc.ComponentDefinition.Occurrences
		Dim oOccs As ComponentOccurrences
		Dim oOcc As ComponentOccurrence
		Dim oSubOccs As ComponentOccurrences
		Dim oSubOcc As ComponentOccurrence
		For Each oOcc In oADef.Occurrences
			If oOcc.Suppressed Then
				'GoTo SkipSuppressed
			Else
			Dim oOccDoc As Document = oOcc.Definition.Document
			Dim oPSets As PropertySets = oOccDoc.PropertySets
			If oOccDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
				If oOccDoc.PropertySets("Design Tracking Properties")("Stock Number").Value = "" Then
					GoTo awshit1
				Else
				Dim oStockSize As String = oOccDoc.PropertySets("Design Tracking Properties")("Stock Number").Value & " - " & oOccDoc.PropertySets("Design Tracking Properties")("Material").Value
				oStockList.Add(oStockSize)
				OccurenceName = oOcc.Name
				Dim CutLength As String
				Try
					CutLength = oOccDoc.PropertySets("Inventor User Defined Properties")("G_L").Value
				Catch
					Try
						CutLength = oOccDoc.PropertySets("Inventor User Defined Properties")("PL").Value
					Catch
						GoTo awshit1
					End Try
				End Try
				Dim oCutLength As Double = Val(CutLength)
			Else
				'MessageBox.Show(oOcc.Name.ToString, "Title")
				oSubADoc = oOccDoc
				oSubADef = oSubADoc.ComponentDefinition
				For Each oSubOcc In oSubADef.Occurrences
					Dim oSubOccDoc As Document = oSubOcc.Definition.Document
					If oSubOccDoc.PropertySets("Design Tracking Properties")("Stock Number").Value = "" Then
						GoTo awshit2
					Else
					Dim oStockSize As String = oSubOccDoc.PropertySets("Design Tracking Properties")("Stock Number").Value & " - " & oSubOccDoc.PropertySets("Design Tracking Properties")("Material").Value
					Try
						CutLength = oSubOccDoc.PropertySets("Inventor User Defined Properties")("G_L").Value
					Catch
						Try
							CutLength = oSubOccDoc.PropertySets("Inventor User Defined Properties")("PL").Value
						Catch
							GoTo awshit2
						End Try
					End Try
					awshit2 :
				Next
			awshit1 :
		Next
		For i = oStockList.Count - 1 To 0 Step -1
			If oStockList.IndexOf(oStockList.Item(i)) <> i Then oStockList.RemoveAt(i)
		Next
		For i As Integer = 0 To oStockList.Count - 1
			If i = 0 Then
				oText = oStockList(i)
			Else
				oText = oText & vbLf & oStockList(i)
		Next
		'MessageBox.Show(oText)
		CreateForm("Select Stock Sizes (cancel with esc)")
		Form :
		MyForm.ShowDialog()
		Dim oUParams As UserParameters = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
		Dim oUParam As UserParameter
		Dim sName As String = "ChosenStockList"
		Try
			oUParam = oUParams.Item(sName)
			oUParam.Delete
			MultiValue.SetList(sName, oChosenStockList.ToArray)
		Catch
			oUParam = oUParams.AddByValue(sName, "", UnitsTypeEnum.kTextUnits)
		End Try
		iPropGet("List Type")
		If oStockList.count = oChosenStockList.Count Then
			iProperties.Value("Custom", "List Type") = "Full"
		Else
			iProperties.Value("Custom", "List Type") = "Partial"
		'For k As Integer = 0 To oChosenStockList.Count - 1
		'			If k = 0 Then
		'				oChosenText = oChosenStockList(k)
		'			Else
		'				oChosenText = oChosenText & vbLf & oChosenStockList(k)
		'			End If
		'		Next
		'MessageBox.Show(oChosenText, "Selected Stock Sizes")
	End Sub
	Private WithEvents MyForm As System.Windows.Forms.Form
	Private Button0 As System.Windows.Forms.Button
	Private Label(0) As System.Windows.Forms.Label
	Private Label0 As System.Windows.Forms.Label
	Public Sub CreateForm(Optional Name As String = vbNullString)
		MyForm = New System.Windows.Forms.Form
		MyForm.Text = Name
		MyForm.AutoScaleMode = AutoScaleMode.Dpi
		MyForm.Size = New Drawing.Size(500, 400) 'Width, Heigth
		MyForm.MinimumSize = MyForm.Size
		MyForm.MaximumSize = MyForm.Size
		MyForm.Font = New Drawing.Font(MyForm.Font.FontFamily, 10)
		MyForm.MaximizeBox = False
		MyForm.MinimizeBox = True
		MyForm.ShowIcon = False
		MyForm.SizeGripStyle = SizeGripStyle.Hide
		MyForm.StartPosition = FormStartPosition.Manual
		MyForm.KeyPreview = True
		AddLabel(10, 5, "Select The Stock Sizes You Want To Include")
		CheckBox()
		ContinueButton()
		Button0.TabIndex = 1
	End Sub
	Public Function CheckBox()
		Y = 0
		For i = 0 To oStockList.Count - 1
			y = y + 25
			Dim oCheckBox As New CheckBox()
			With oCheckBox
				.Text = oStocklist(i)
				oCheckBox.Top = y
				.Left = 25
				.AutoSize = True
			End With
			AddHandler oCheckBox.CheckedChanged, AddressOf oCheckBox_CheckedChanged
			MyForm.Controls.Add(oCheckBox)
		Next
	End Function
	Public Function ContinueButton() As System.Windows.Forms.Button
		Button0 = New System.Windows.Forms.Button
		Button0.Name = " Button0 "
		Button0.Location = New Drawing.Point(10, Y + 25)
		Button0.Text = "Continue"
		Button0.Width = 465
		Button0.Height = 25
		MyForm.Controls.Add(Button0)
		AddHandler Button0.Click, AddressOf Button0Click
		Return Button0
	End Function
	Public Sub Button0Click()
		MyForm.Close
	End Sub
	Private Sub MyForm_FormClosing(ByVal sender As Object, ByVal E As System.Windows.Forms.FormClosedEventArgs) Handles MyForm.FormClosed
		If sender.Name = "CloseButton" Then
			'MessageBox.Show(sender.Name)
	End Sub
	Private Sub MyForm_KeyDown(ByVal sender As System.Object, ByVal E As System.Windows.Forms.KeyEventArgs) Handles MyForm.KeyDown
		If E.KeyCode = Keys.Escape Then
			MyForm.Close
			ExitSub = True
	End Sub
	Private Function AddLabel(PosX As Integer, PosY As Integer, Optional Caption As String = vbNullString, Optional Width As Integer = 100) As System.Windows.Forms.Label
		Dim LC As Integer = Label.Length - 1
		If Not Label(LC) Is Nothing Then
			LC = LC + 1
			ReDim Preserve Label(LC)
		Label(LC) = New System.Windows.Forms.Label
		Label(LC).Name = "L" & LC
		Label(LC).Location = New Drawing.Point(PosX, PosY)
		Label(LC).Text = Caption
		Label(LC).AutoSize = True
		Label(LC).Width = Width
		MyForm.Controls.Add(Label(LC))
		Return Label(LC)
	End Function
	Private Sub oCheckBox_CheckedChanged(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs)
		'oSender is a CheckBox
		If oSender.Checked = True Then
			'MsgBox("You just Checked the [" & oSender.Text & "] checkbox.", vbOKOnly + vbInformation, "EVENTFEEDBACK")
			oChosenStockList.Add(oSender.Text)
		Else
			'	MsgBox("You just UnChecked the [" & oSender.Text & "] checkbox.", vbOKOnly + vbInformation, "EVENTFEEDBACK")
			oChosenStockList.Remove(oSender.Text)
	End Sub
	Function iPropGet(PropName As String, Optional MissingSetVal As Object = "", Optional Doc As Inventor.Document = Nothing) As Object
		If Doc Is Nothing Then Doc = ThisDoc.Document
		Dim CustomPropSet As Inventor.PropertySet = Doc.PropertySets.Item("Inventor User Defined Properties")
		Try
			Dim CurrentValue As Object = CustomPropSet.Item(PropName).Value
			Return CurrentValue
		Catch
			Dim oTransaction As Inventor.Transaction
			Try
				oTransaction = ThisApplication.TransactionManager.StartTransaction(Doc, "Create property """ & PropName & """")
				CustomPropSet.Add(MissingSetVal, PropName)
				oTransaction.End
				Return MissingSetVal 'Successfully created/set.
			Catch
				If Not oTransaction Is Nothing Then oTransaction.Abort
				Return -1 'Unable to create.
			End Try
		End Try
	End Function
End Class
ErikMebo
Hi JW,
First of all: Thank you for you very elaborate reply.
Secondly: This is way above my level of Ilogic understanding at the moment. I tried to understand the code and what it does, but am pretty sure I missed at least 50%.
Nevertheless, I'll test it after hours ad see what I can learn from it. But am not sure I'll be able to apply it in this project yet.
Have a nice day.
Erik
HermJan.Otterman
hi Erik,
an other approach  could be not to create a parameter for this, but a property. to create that property in all parts in an assembly, you don't need code, you can easily do this in the BOM by adding a custom property (column). open it, add an new property, make it yes / no, than add a yes in one line, and copy that yes to all other lines.
so no code needed than.
but of course you can also make some code for it, or change you template files so they will always have the properties that you need.
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
