iLogic to export STP file for individual Model State
frahaman7SKBG
frahaman7SKBG
Does anyone know how to export individual Model States in STP format using iLogic? I have 100+ Model State with Multibody in a single ipt file, need to export them in STP file.
theo.bot
You should Loop thru the modelstates, activate each modelstate and then do a save as Step
Here is a small sample:
Sub Main
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim oModelState As ModelState
For Each oModelState In oDoc.ComponentDefinition.ModelStates
	Logger.Info(oModelState.Name)
	If oModelState.Name <> "Master" Then
		oModelState.Activate
		ExportStep(oModelState.Name)
Next
End Sub
Sub ExportStep (ByVal oState As String)
	' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oPath = ThisDoc.Path
oFolder = oPath & "\Step"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
If oSTEPTranslator.HasSaveCopyAsOptions(ThisDoc.Document, oContext, oOptions) Then
    ' Set application protocol.
    ' 2 = AP 203 - Configuration Controlled Design
    ' 3 = AP 214 - Automotive Design
    oOptions.Value("ApplicationProtocolType") = 3
    ' Other options...
    'oOptions.Value("Author") = ""
    'oOptions.Value("Authorization") = ""
    'oOptions.Value("Description") = ""
    'oOptions.Value("Organization") = ""
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
    oData.FileName = oFolder & "\" & ThisDoc.FileName(False) & "-" & oState & ".stp"
oSTEPTranslator.SaveCopyAs(ThisDoc.Document, oContext, oOptions, oData)
End Sub
frahaman7SKBG
Thank you so much @ theo.bot, it works flawlessly.
