iLogic loop to read rows from Excel
frahaman7SKBG
Message 1 of 9
frahaman7SKBG
Hi guys,
Looking for your help here again. Thank you in advance for all the help I have been getting from this forum.
Im looking to write a script to read individual rows from excel doc and push that value to the 'Custom iProperty' for each part in that assembly and run a series of other iLogic rules I have set (to update that part based on the set Custom iProperty). And once those rules finished running, I want to export a copy of this assembly (iam) file in STP format. The name of the stp file should be the same value it grabbed earlier from the excel row. And then repeat this for every column in that excel.
My current project has over 50 rows, that I need to create 50 STP files for. I would like to automate this process as much as possible.
Thank you again for your time.
Replies (8)
Message 2 of 9
WCrihfield
Hi @frahaman7SKBG.  Your task does sound possible to automate by iLogic code.  Obviously there are a lot of variables involved that may complicate things though.  In a task this big, we will need every little detail you can think of, so we have the knowledge about it that you have.
  • Excel file's full file name (path, name, & file extension)
  • Excel sheet's name
  • Where on the sheet is the data we are after?
    • Is there a title row?  Where?
    • Are there column titles or row titles?  Where?
    • What row & column does the actual data start, and how is the data laid out?
    • Are there blank cells in this data set.
  • Are we only going to be exporting Parts within the assembly, or parts & sub-assemblies?
  • First level components only, all level components, or other?
  • Are there content center components (or other read only stuff) involved that will need to be avoided?
  • Are there some components set to Reference or Phantom or Purchased that will need to be avoided?
  • (There are probably other questions too, so if you can thing of anything else that we might need to know...)
Since your real assembly may have 50+ components, I would suggest creating a simplified test assembly & Excel file to test any code posted here on, before trying it on the real thing, just to be safe, because we might not have a file set to pre-test on.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 9
frahaman7SKBG
Hi @WCrihfield
Thank you again for all your help.
To give a bit more context to my project. I have a multi-body with 50+ Model States. And I have a full Assembly that is derived from the Model States. The excel sheet list all the Model states in a single column. I have rules currently that I put together using various snippets from this forum that can toggle between the Model States based on the user input. Here is the forum where I published those codes:
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-code-to-change-between-model-sta...
Next step in my project is to publish each of the Model State assemblies in the STP file and also in the rfa file. I thought the best way to approach this (open to suggestion here) is to list the Model State in Excel sheet and have an iLogic loop to retrieve each cell from that excel that contains the Model State. And then, run the above rules to update the assembly with that Model State and publish an STP file and a rfa file.
Here is the answer to your list:
-Path: C:\Users\frahaman\Documents
-Name: Model State List.xlsx
-Model State List.xlsx
(I have attached the Excel file)
-Export just the Assembly as STP file and rfa file
-Just the First Level only
-no CC components, all parts are drived from Multi-body Modle State ipt file
-No phantom or reference file
Message 4 of 9
WCrihfield
OK.  I'm trying to plan out the whole project in my mind ahead of writing the code out to do it.  I'm honestly not too familiar with the process of deriving an assembly from a multi-body part, especially when ModelStates are involved, and how those ModelStates carry over into the new documents.  If I'm understanding the situation correctly, the main assembly here that was derived from the master multi-body part does not contain this list of ModelStates itself, but each of the components within this main assembly do have this list of ModelStates defined within them, correct.  I assume that is why you are using a custom iProperty in both the main assembly and in those components as a 'middle man' to relay which ModelState you want to set each component within the assembly to, instead of setting an active ModelState within the main assembly.
Also, as I understand the 'steps' so far, Step 1 previously was to simply to ask the user which ModelState they want to switch all the assembly components to.  But in this case, instead of using an InputBox like in your earlier rule, you want to pull a series of ModelState names from the Excel sheet and loop through them in this process.  Does that sound right?
Then Step 2 is just to push the ModelState (for the current loop in this case) to the assembly's custom iProperty, then to the same custom iProperty of each of the components within the assembly.
Then Step 3 is to run the local rule within each of the assembly's components that will update the component to the chosen ModelStatte.
Then Step 4 takes place after Step 3 has finished, but before moving to the next ModelState name in the main loop of ModelState names (from Step 1), and this step is to export the main assembly as a STEP file, and as an RTA file, right?  I know that RTA files are for Revit, but I don't currently use Revit, but I am aware that Inventor 2022 works more closely with it now.  Would this be the Translator add-in named "Translator: RVT", that produces those ".rta" files?  If so, I can most likely figure it out, or at least get you a good starting point for that export process code.
It seems like most of these steps could be combined into one larger iLogic rule with sub routines, if that would suit your needs.  Especially since steps 2, & 3 are both so similarly looping through all components/refdocs of the assembly.
Wesley Crihfield
Message 5 of 9
WCrihfield
I have constructed most of this main external rule code now.  The main part of this code I am unsure of is the sub routine for exporting the assembly as an ".rta" file.  I inspected that translator add-in named "Translator: RVT" in an attempt to extract what 'Options' are exposed/available for us to specify within the code for it.  It did not return anything, which seems a bit odd to me, since when you attempt to export an assembly using the manual process (File tab > Export > RVT) , it has tons of options in its dialog box.  But maybe that's not the right translator for creating the ".rta" files you are referring to, I'm not sure.  Also, this code accesses the Excel application and its objects directly, instead of using the iLogic GoExcel tools, so if you don't have the real Excel installed, it might fail.
Anyways, here is the what I have so far.  Please revue it carefully before attempting to run it on your main assembly.  You might even create a simpler, smaller set of files to test it on, just to test functionality first, to be safe.
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop.Excel
Sub Main
	'get the 'active' main assembly
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "iLogic")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	oADef = oADoc.ComponentDefinition
	oAuto = iLogicVb.Automation
	oLocalRuleName = "Update_Model_State"
	oExcelFile = "C:\Users\frahaman\Documents\Model State List.xlsx"
	oExcelSheet = "Sheet1"
	Dim oExcelRow As Integer = 2 'starting with 2, because first data row in Excel is row 2
	'<<<< MAKE SURE ALL CELLS IN COLUMN SERIES HAVE VALUE >>>>
	'<<<< WHEN EMPTY ONE IS ENCOUTERED, IT WILL EXIT RULE >>>>
	For Each oOcc As ComponentOccurrence In oADef.Occurrences
		'retrieve the ModelState name from Excel
		Dim oModelStateName As String = String.Empty 'ensuring no carryover value
		oModelStateName = GetModelStateName(oExcelFile, oExcelSheet, oExcelRow)
		If String.IsNullOrEmpty(oModelStateName) Then
			MsgBox("Failed to retrieve ModelState name from Excel.  Exiting rule.", vbCritical, "iLogic")
			Exit Sub
		'push that ModelState name to the assembly's custom iProperty
		iProperties.Value("Custom", "Model_State:") = oModelStateName
		'push that ModelState name to custom iPropertis of Components
		iProperties.Value(oOcc.Name, "Custom", "Model_State:") = oModelStateName
		'get the Document that the component represents
		Dim oOccDoc As Document = Nothing 'ensuring no carryover value
		oOccDoc = oOcc.Definition.Document
		'get the local rule in that document
		Dim oRule As iLogicRule = Nothing 'ensuring no carryover value
		oAuto.GetRule(oOccDoc, oLocalRuleName)
		If Not IsNothing(oRule) Then
			oAuto.RunRuleDirect(oRule)
		'update the main assembly now to ensure changes are in place before export processes
		oADoc.Update2(True) 'True = Accept Errors & Continue
		'run export process sub routines here
		ExportAssemblyToSTEP(oADoc, oModelStateName)
		ExportAssemblyToRFA(oADoc, oModelStateName)
		'advance to next row in Excel for next loop
		oExcelRow = oExcelRow + 1
	Next
	'just a final message to indicate that the process has finished
	MsgBox("Finished All Export Processes.", vbInformation, "iLogic")
End Sub
Function GetModelStateName(oXLFile As String, oXLSheet As String, oXLRow As Integer) As String
	Dim oExcel As Microsoft.Office.Interop.Excel.Application = GetExcel
	If oExcel Is Nothing Then Return String.Empty
	Dim oWB As Workbook
	Try
		oWB = oExcel.Workbooks.Open(oXLFile)
	Catch oEx As Exception
		MsgBox("Failed to open specified Excel file." & vbCrLf & _
		oEx.Message & vbCrLf & oEx.StackTrace, vbCritical, "iLogic")
		Return String.Empty
	End Try
	Dim oWS As Worksheet
	Try
		oWS = oWB.Worksheets.Item(oXLSheet)
		MsgBox("Couldn't find specified Excel Sheet." & vbCrLf & _
		Return String.Empty
	End Try
	Dim oMSName As String
	If IsNothing(oWS.Range("A" & oXLRow.ToString)) Then
		Return String.Empty
	Else
		oMSName = CStr(oWS.Range("A" & oXLRow.ToString).Value2)
	Return oMSName
End Function
Sub ExportAssemblyToSTEP(oAssembly As AssemblyDocument, oMSName As String)
	'your code for exporting the assembly to a STEP file here
	'get the STEP translator add-in
	Dim oSTEP As TranslatorAddIn
	For Each oAddIn As ApplicationAddIn In ThisApplication.ApplicationAddIns
		If oAddIn.DisplayName = "Translator: STEP" Then
			oSTEP = oAddIn
	Next
	If IsNothing(oSTEP) Then
		MsgBox("STEP Translator Add-in not found.  Exiting.", vbCritical, "iLogic")
		Exit Sub
	'create needed variables for translator
	oTO = ThisApplication.TransientObjects
	oContext = oTO.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = oTO.CreateNameValueMap
	oDataMedium = oTO.CreateDataMedium
	'specify full file name of new STEP file it is to create
	'get path of assembly, without file name or file extension
	oPath = System.IO.Path.GetDirectoryName(oAssembly.FullFileName)
	oDirChar = System.IO.Path.DirectorySeparatorChar
	'integrate ModelState name in place of file name
	oNewFile = oPath & oDirChar & oMSName & ".stp"
	'Check to see if the STEP file already exists, if it does, ask if you want to overwrite it or not.
	If System.IO.File.Exists(oNewFile) Then
		oAns = MsgBox("A STEP file with this name already exists." & vbCrLf &
		"Do you want to overwrite it with this new one?",vbYesNo + vbQuestion + vbDefaultButton2, "STEP FILE EXISTS")
		If oAnswer = vbNo Then Exit Sub
	oDataMedium.FileName = oNewFile
	If oSTEP.HasSaveCopyAsOptions(oAssembly, oContext, oOptions) Then
		' Set application protocol.
		' 2 = AP 203 - Configuration Controlled Design
		' 3 = AP 214 - Automotive Design
		oOptions.Value("ApplicationProtocolType") = 3
		'oOptions.Value("IncludeSketches") = True
		'oOptions.Value("export_fit_tolerance") = .000393701  'minimum
		'oOptions.Value("Author") = ThisApplication.GeneralOptions.UserName
		'oOptions.Value("Authorization") = ""
		'oOptions.Value("Description") = iProperties.Value("Summary", "Title")
		'oOptions.Value("Organization") = iProperties.Value("Summary", "Company")
		Try
			 oSTEP.SaveCopyAs(oAssembly, oContext, oOptions, oDataMedium)
		Catch
			MsgBox("Your attempt to export this document as a STEP file FAILED!", vbOKOnly + vbExclamation, "Export to STEP Error")
		End Try
End Sub
Sub ExportAssemblyToRFA(oAssembly As AssemblyDocument, oMSName As String)
	'your code for exporting the assembly to a RFA file here
End Sub
Function GetExcel() As Microsoft.Office.Interop.Excel.Application
	Dim oXL As Microsoft.Office.Interop.Excel.Application
	Try
		'try to find an already running instance of the Excel Application
		oXL = GetObject(, "Excel.Application")
	Catch
		'it wasn't found open, so create an instance of it (start the application)
		oXL = CreateObject("Excel.Application")
		'oXL = New Microsoft.Office.Interop.Excel.Application
	Catch
		MsgBox("Failed to Get/Create an instance of the Excel Application. Exiting.", , "")
		Exit Function
	End Try
	Return oXL
End Function
Wesley Crihfield
Message 6 of 9
frahaman7SKBG
Thank you for your help on this, you are a rockstar in this forum @WCrihfield .
I have done some testing of your code on a dummy model, for the most part it works perfectly. For some reason after the custom iProperty update from the excel sheet, the model would not get updated. I 'commented' out that section of the code and used 'RunRule' function to call up my separate script that would update each and it looks like it did the trick. Did some tests and it worked perfectly, everything would update.
For the RFA export, I used your code from this thread
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/export-main-assembly-to-rfa-file-using-...
And it look like it does export the rfa file, but it over writes it for each. I need to figure out how to use the Model_State name for each rfa file so it creates a new one for each.
Here is the main code:
Sub Main
		Exit Sub
			Exit Sub
'		'get the Document that the component represents
'		Dim oOccDoc As Document = Nothing 'ensuring no carryover value
'		oOccDoc = oOcc.Definition.Document
'		'get the local rule in that document
'		Dim oRule As iLogicRule = Nothing 'ensuring no carryover value
'		oAuto.GetRule(oOccDoc, oLocalRuleName)
'		If Not IsNothing(oRule) Then
'			oAuto.RunRuleDirect(oRule)
'		End If
iLogicVb.RunRule("Update iProperty for Model State")
iLogicVb.RunRule("Change Model State for all the parts")
	Next
End Sub
	Dim oWB As Workbook
	Try
		Return String.Empty
	End Try
	Try
		Return String.Empty
	End Try
		Return String.Empty
	Else
	Return oMSName
End Function
			oSTEP = oAddIn
	Next
		Exit Sub
		Try
		Catch
		End Try
End Sub
	MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
	Exit Sub
'gets the 'active' assembly document
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
'same path & file name as active assembly, but with ".rfa" file extension
Dim oFFN As String = System.IO.Path.ChangeExtension(oADoc.FullFileName, ".rfa")
'export
oADef.BIMComponent.ExportBuildingComponent(oFFN)
End Sub
	Try
		oXL = GetObject("Excel.Application")
	Catch
	Catch
		Exit Function
	End Try
	Return oXL
End Function
Here is my code for "Update iProperty for Model State"
Sub Main
'Gets the Active Document
oDoc = ThisDoc.Document
'Saves this document
oDoc.Save
'Checks if the active document is an assembly
If oDoc.DocumentType = kAssemblyDocumentObject
	'Gets the assembly occurrences
	Dim oOccs As ComponentOccurrences
	oOccs = oDoc.ComponentDefinition.Occurrences
	'Call the subprocedure to traverse the assembly
	Call TraverseAssembly(oOccs)
End Sub
Public Sub TraverseAssembly(oOccs As ComponentOccurrences)
 'Integer to traverse the assembly occurrences
 Dim i As Integer
 'For i=1 To oOccs.Count
  Dim oOcc As ComponentOccurrence
For Each oOcc In oOccs
  'oOcc = oOccs.Item(i)
 	If oOcc.Suppressed = False
		'Occurrence Name (Display Name)
		oOccName = oOcc.Name
		'Gets the first three leters of the Occurrence Name (e.g. "STK")
		oOccPrefix = Left(oOccName, 3)
		If oOccPrefix <> "STK"
			Try
				iProperties.Value(oOccName, "Custom", "Model_State:") = iProperties.Value("Custom", "Model_State:")
			Catch
				'It won't be able to change Read-Only parts (e.g. Content Center)
				'MessageBox.Show("This is a content center file: " & oOcc.Name, "Title")
			End Try
		If oOcc.DefinitionDocumentType = kAssemblyDocumentObject
			Call TraverseAssembly(oOcc.SubOccurrences)
Next
End Sub
Here is the code for the "Change Model State for all the parts"
Sub Main
auto = iLogicVb.Automation
' Set Rule name
Dim ruleName As String
ruleName = "Update_Model_State"
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
' Get all of the referenced documents.
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
' Iterate through the list of documents.
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
	Dim rule As Object
	rule = auto.GetRule(oRefDoc, ruleName)
	If (rule Is Nothing) Then
'	Call MsgBox("No rule named " & ruleName & " was found in the document.")
	Else
'	MessageBox.Show(rule.Name, oRefDoc.DisplayName)
	Dim i As Integer
	i = auto.RunRuleDirect(rule)
Next
End Sub
And here is the Local code for each individual component"Update_Model_State"
Dim doc As PartDocument = ThisDoc.Document
Dim comp As DerivedPartComponent = doc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1)
Dim derivedDef = comp.Definition
Logger.Info("current model state = {0}", derivedDef.ActiveModelState)
Dim stateWanted = iProperties.Value("Custom", "Model_State:")
If (derivedDef.ActiveModelState <> stateWanted) Then
	derivedDef.ActiveModelState = stateWanted
	comp.Definition = derivedDef ' apply the modified definition back to the DerivedPartComponent
Message 7 of 9
WCrihfield
Oh.  I totally forgot about that other post, and did not remember what that file type was for, because I never use it.  Maybe I can tackle this more tomorrow.
Wesley Crihfield
Message 8 of 9
WCrihfield
OK.  I think I messed up the process I originally had in mind, and that's why you are still needing to run those two other rules to make stuff happen.  I should have first gotten the list of model state names from the Excel sheet, then the main loop in the rule will be looping through each of those names.  Within each loop, update the main assembly's custom iProperty to this model state name, then loop through every component, updating its custom iProperty, then running its local rule to change its model state.  Then right after the loop of components, but still inside the loop of names, update the main assembly, then export the main assembly to the two file formats.  Then loop to the next model state name.
I also modified the 'ExportAssemblyToRFA' sub routine to what I believe is the way you are wanting it.  It should now be naming the files similarly to the STEP files, but with the ".rfa" file extension.  (assembly's original path, model state name, then ".rfa" file extension)
	oADef = oAssembly.ComponentDefinition
	oDirChr = System.IO.Path.DirectorySeparatorChar
	oFFN = oPath & oDirChr & oMSName & ".rfa"
	'export
End Sub
So here is the finished final code.  It doesn't run those two other external rules, but just runs the one local rule in each component.
Sub Main
		Exit Sub
	Dim oExcelDataStartRow As Integer = 2 'starting with 2, because first data row in Excel is row 2
	Dim oMSNames As List(Of String) = GetModelStateNames(oExcelFile, oExcelSheet, oExcelDataStartRow)
	'now loop through these ModelState names as the main loop in this rule
	For Each oMSName In oMSNames
		If String.IsNullOrEmpty(oMSName) Then Continue For
		'push this ModelState name to the main assembly's custom iProperty
		iProperties.Value("Custom", "Model_State:") = oMSName
		'loop through each component, update its iProperty, and run its local rule
			'push that ModelState name to custom iProperty of this component
			iProperties.Value(oOcc.Name, "Custom", "Model_State:") = oMSName
			'oOcc.ActiveModelState = oMSName
			'get the Document that the component represents, so that we can run the local rule in it
		Next
		'now main assembly and all components have updated iProperty
		'and local rule has been ran in each component to change its ModelState
		'now update the main assembly now to ensure changes are in place before export processes
	Next 'go to next ModelState name in the list we got from Excel
End Sub
Function GetModelStateNames(oXLFile As String, oXLSheet As String, oXLRow As Integer) As List(Of String)
	If oExcel Is Nothing Then Return Nothing
	Dim oWB As Workbook
	Try
		Return Nothing
	End Try
	Try
		Return Nothing
	End Try
	'determine last used row, so we know the limits of our loop through the rows
	Dim oLastRowUsed As Integer = oWS.UsedRange.Rows.Count
	'create variable to hold them all
	Dim oNames As New List(Of String)
	'loop through rows and add each name to the list
	For oRow As Integer = oXLRow To oLastRowUsed
		Dim oName As String = String.Empty
		If IsNothing(oWS.Range("A" & oRow.ToString)) Then
			'if an empty Cell is found in the series, it will stop,
			'and return the list without any further names added
			Return oNames
		Else
			oName = CStr(oWS.Range("A" & oRow.ToString).Value2)
		oNames.Add(oName)
	Next
	Return oNames
End Function
			oSTEP = oAddIn
	Next
		Exit Sub
		Try
		Catch
		End Try
End Sub
	'export
End Sub
	Try
	Catch
	Catch
		Exit Function
	End Try
	Return oXL
End Function
It kind of seems to me like this whole job could be done much simpler though, without needing to use any iProperties, or any other rules.  What if we simply got the list of names from Excel (like I'm doing in this last code), then while looping through those names, simply directly change the ActiveModelState of each component to the name in this loop.
Like with this line:
It seems to me like that would eliminate the need for the custom iProperties and running the local rule for each component.  Besides, that local rule is running on the Document that the component represents, not just the one specific component occurrence in the assembly.  So if there were multiple components representing the same part, and you may want different ones to be at different model states, this would mess that up.  I did notice that the local rule seems to be digging down pretty deep before setting the ModelState.  Does that main document not have its own set of model states that match the list?  I have no idea, because like I said, I'm not familiar with the effects of derived stuff from multi-body parts, so I could be wrong about this last idea.
Wesley Crihfield
Message 9 of 9
frahaman7SKBG
Hi @WCrihfield ,
For some reason, the code doesn't grab the Model State Name for the file name. It just outputs as .stp and .rfa and it asks to overwrite the files for the next as these names already exist.
And you are probably right, there is probably a simpler way of doing this than what I have going on here. I have not thought of it as I don't know or understand the full capability of iLogic.
Thank you again for all your help on this.
