Count all sub assemblies and parts - with merged part numbers
darrell.wcd
darrell.wcd
I have patched together some ilogic that I found on this forum..
My intent is to iterate through the assembly and take the custom iProperty (Contract Number) and basically the (item number) and the REV letter to create a stock number which I will use as a short part number. Since I found that the Item number is not accessible via iLogic.. that is not an option. Unless there is a way to do that.
My part number is to long as I have parts that have 30+ options that are defined in the part number in order to merge parts on the BOM. (190854-17.75-1.75-1.75-0.1-10.5-7-SS-W) my vendors software has a 12 character limit, so even removing the "-" would not shorten it enough.
This also needs to include all the sub assemblies and parts, and it also needs to change the stock number of all instances, due to the part number merge, otherwise i get a stock number that says varies.
I cant seem to get the "PNum" to keep counting, I just need  "PNum" to keep counting so I don't end up with the same number in either a part or sub assembly. And when I turn off the "On Error Resume Next" I get
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at ThisRule.ListItems(BOMRowsEnumerator Rows, Int32 indent, Document oDoc)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
some pointers or rewritten illogic would be much appreciated.
	Sub Main()
		'On Error Resume Next
		numFiles = 0
		Dim oAssem As AssemblyDocument = ThisDoc.Document
		Dim oBOM As BOM = oAssem.ComponentDefinition.BOM
		Dim BoxNote As String = "Drawing Automation"
		ANum = ANum + 1
		Dim oModelREV1 As String = oAssem.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").ItemByPropId(9).Value
		Dim oModelConN1 As String = oAssem.PropertySets("Inventor User Defined Properties").Item("Contract Number").Value
		oAssem.PropertySets("Design Tracking Properties").Item("Stock Number").Value = oModelConN1 & "-AS" & ANum & "-" & oModelREV1
		oBOM.StructuredViewFirstLevelOnly = False
		oBOM.StructuredViewEnabled = True
		oBOM.PartsOnlyViewEnabled = True
		oBOM.SetPartNumberMergeSettings(True, )
		For Each oDoc In oAssem.AllReferencedDocuments
			numFiles = numFiles + 1
			If oDoc.DocumentType = 12291 Then Call ListItems(oBOM.BOMViews.Item(1).BOMRows, 0, oDoc) 'assembly
			If oDoc.DocumentType = 12290 Then Call ListItems(oBOM.BOMViews.Item(3).BOMRows, 0, oDoc) 'part
			MessageBox.Show(numFiles)
		Next
		MessageBox.Show("Thanks for being efficient!" _
		& vbLf & "There are   (  " & numFiles & "  )   files that have been updated.", BoxNote, MessageBoxButtons.OK)
	End Sub
	Sub ListItems(Rows As BOMRowsEnumerator, indent As Integer, oDoc As Document)
	PNum = PNum + 1
		'MessageBox.Show ("PNum")
		For Each oBOMRow As BOMRow In Rows
			rDoc = oBOMRow.ComponentDefinitions.Item(1).Document
			If rDoc IsNot oDoc Then
				If Not oBOMRow.ChildRows Is Nothing Then
					Call ListItems(oBOMRow.ChildRows, indent + 1, oDoc)
			Else
				i = 1
				For Each kDoc In  oBOMRow.ComponentDefinitions
					rDoc = oBOMRow.ComponentDefinitions.Item(i).Document
					Dim oModelREV As String = oDoc.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").ItemByPropId(9).Value
					Dim oModelConN As String = rDoc.PropertySets("Inventor User Defined Properties").Item("Contract Number").Value
					rDoc.PropertySets("Design Tracking Properties").Item("Stock Number").value = oModelConN & "-" & PNum & "-" & oModelREV
					PNum = PNum + 1
					MessageBox.Show(PNum)
					i = i + 1
					Next
		Next
	End Sub
JelteDeJong
does this work for you:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim pNum = 1
For Each refDoc As Document In doc.AllReferencedDocuments
    Dim oModelREV As String = refDoc.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").ItemByPropId(9).Value
    Dim oModelConN As String = "<unknown>"
    Try
        oModelConN = refDoc.PropertySets("Inventor User Defined Properties").Item("Contract Number").Value
    Catch ex As Exception
    End Try
    Dim newStockNumber = String.Format("{0}-{1}-{2}",
        oModelConN, pNum, oModelREV)
    refDoc.PropertySets("Design Tracking Properties").Item("Stock Number").Value = newStockNumber
    pNum = pNum + 1
Next
Jelte de Jong
Blog: hjalte.nl - github.com
darrell.wcd
No it doesn't..  because it give each instance a specific incremental number, and then when I go to parts only... it says *varies* on any that are merged because they are not the same number...
JelteDeJong
oke 2e try.
Dim knowPartNumbers As New Dictionary(Of String, Integer)
Dim pNum = 1
    Dim partNumber As String = refDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value
    Dim oModelREV As String = refDoc.PropertySets("Inventor Summary Information").Item("Revision Number").Value
    Try
    End Try
    Dim newStockNumber As String
    If (knowPartNumbers.ContainsKey(partNumber)) Then
            oModelConN, knowPartNumbers.Item(partNumber), oModelREV)
    Else
        knowPartNumbers.Add(partNumber, pNum)
        pNum = pNum + 1
Next
Jelte de Jong
darrell.wcd
The error I get
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Property.set_Value(Object )
at ThisRule.Main()
darrell.wcd
@JelteDeJong
I think I got this to work, see code below.
But is there a way I can format the incremental number to be 01, 02,... 12, 13 etc?
Sub Main()
'zero counters
numFiles = 0
numerros = 0
numPurchase = 0
Dim BoxNote As String = "WCD Drawing Automation"
Dim pNum = 1
	'MessageBox.Show(partNumber)
	numFiles = numFiles+1
	Dim oModelProcess As String = refDoc.PropertySets("Inventor User Defined Properties").Item("Process").Value
	'MessageBox.Show(oModelProcess)
	'check if file is normal on BOM
	If refDoc.ComponentDefinition.BOMStructure <> BOMStructureEnum.kNormalBOMStructure Then Continue For
	'dont work with purhase items
	If oModelProcess = "Purchase" Then
		numPurchase = numPurchase + 1
		'MessageBox.Show(partNumber & " is purchase item")
		GoTo 2
	'check If File Is read only
	Dim fi As New System.IO.FileInfo(refDoc.FullFileName)
	If fi.IsReadOnly = True Then
		'MessageBox.Show(partNumber & " is read only")
		numerros = numerros+1
		GoTo 2
    Try
    End Try
        newStockNumber = String.Format("{0}-{1}-{2}",oModelConN, knowPartNumbers.Item(partNumber), oModelREV)
    Else
        newStockNumber = String.Format("{0}-{1}-{2}",oModelConN, pNum, oModelREV)
	    pNum = pNum + 1
	Try
	Catch
		MessageBox.Show(partNumber & " error")
	End Try
	2 :
Next
MessageBox.Show("There were (" & numerros & ") that are read only and not updated." _
& vbLf & "There were (" & numPurchase & ") Purhase items not updated." _
& vbLf & "There were (" & numFiles & ") looked at!" _
& vbLf & "" _
& vbLf & "Please check the BOM and verify that all Stock Numbers are correct!", BoxNote, MessageBoxButtons.OK, MessageBoxIcon.Error)
End Sub
JelteDeJong
I checked your code and changed a few things. Also, I added a leading zero or the numbers.
'zero counters
Dim numFiles = 0
Dim numerros = 0
Dim numPurchase = 0
Dim pNum = 1
    Dim oModelProcess As String = "<unknown>"
    Try
        oModelProcess = refDoc.PropertySets("Inventor User Defined Properties").Item("Process").Value
    End Try
        Continue For
        numerros = numerros + 1
        Continue For
    Try
    End Try
                                       oModelConN,
                                       oModelREV)
    Else
                                       oModelConN,
                                       String.Format("{0:00}", pNum),
                                       oModelREV)
        pNum = pNum + 1
    Try
    Catch
    End Try
Next
& vbLf & "" _
Jelte de Jong
