iLogic to delete suppressed features in .ipt
jamieking89
jamieking89
Hi
I am wondering if anyone could help with wirting ilogic code i could use in a rule that will delete all suppressed features. I did find something that does this online however it wouldnt delete all in one run of the rule, it needed multiple runs.
Jamie
mcgyvr
Dim oFeature As PartFeature
oFeatures = ThisApplication.ActiveDocument.ComponentDefinition.Features
For Each oFeature In oFeatures
	'get the name of the feature
	oName = oFeature.Name
	'if the feature is not active (suppressed)
If Feature.IsActive(oName) = False
	'delete it
	oFeatures(oName).delete
Next
jamieking89
Hi mcgyvr
Thanks for the quick response however when trying to run a rule with that ilogic within it i get an error code. (please see attached)
mcgyvr
Try this..
I'm not positive on the answer but I suspect that feature to feature dependencies are causing errors to be generated..
This will ignore them..
	MessageBox.Show(oName, "Processing")
	'delete it
On Error Resume Next
Next
Curtis_Waguespack
Hi @jamieking89
Keep in mind that if you attempt to delete a feature with dependent items (other features or sketches, etc) you will see an error... adding a resume next line should catch and silence those errors.
Also, just a reminder that the the Inventor Customization forum is the better forum for ilogic and coding questions:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
Here is a previous topic on that forum that relates to your question:
https://forums.autodesk.com/t5/inventor-customization/ilogic-delete-suppressed-features-and-un-used-...
I've asked the moderators to move your this topic to that forum.
I hope this helps.
Curtis
	'delete it
Next
jamieking89
Hi Curtis
That now works. Thanks for that.
Shall keep that in mind for future when posting regarding ilogic related questions.
Thanks again for your help.
Jamie
jamieking89
Thanks for you help.
Much appreciated.
Jamie
