iLogic rules from 2019 to 2020
In the Inventor 2019 version this rule works correctly, but in the Inventor 2020 version the rule does not work correctly, it does not perform the "Try" part.
Why?
Rule:
Dim oComps As DocumentsEnumerator
oComps = ThisApplication.ActiveDocument.AllReferencedDocuments
Dim oComp As Document
    For Each oComp In oComps
	Try
		iLogicVb.RunRule(oComp.DisplayName & ":1", "tempo")
	Catch
		ThisApplication.Documents.Open(oComp.FullFileName)
		ThisApplication.Documents.Open(oComp.FullFileName).Close
	End Try
	Next
CattabianiI
Already posted in the right place.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Please provide non confidential assembly files to reproduce the error.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
The problem has been resolved on this page:
https://forums.autodesk.com/t5/inventor-customization/ilogic-rules-from-2019-to-2020/td-p/9330794
	Try
		'iLogicVb.RunRule(oComp.DisplayName & ":1", "Tempo")
iLogicVb.RunRule(oComp.DisplayName, "Tempo") Catch ThisApplication.Documents.Open(oComp.FullFileName) ThisApplication.Documents.Open(oComp.FullFileName).Close End Try Next
Tank you
