iLogic rules from 2019 to 2020
In the Inventor 2019 version this rule works correctly, but in the Inventor 2020 version the rule does not work correctly, it does not perform the "Try" part.
Why?
Rules:
Dim oComps As DocumentsEnumerator
oComps = ThisApplication.ActiveDocument.AllReferencedDocuments
Dim oComp As Document
    For Each oComp In oComps
	Try
		iLogicVb.RunRule(oComp.DisplayName & ":1", "Tempo")
	Catch
		ThisApplication.Documents.Open(oComp.FullFileName)
		ThisApplication.Documents.Open(oComp.FullFileName).Close
	End Try
	Next
WCrihfield
Have you checked your iLogic Rule Editor dialog Options tab to check if "Don't run Automatically", "Silent Operation", and Fire Dependant Rules Immediately" are checked?
Also try "Reginerate All Rules tool, after the new install.
Also check these settings.
iLogicAuto.RulesEnabled = True
iLogicAuto.RulesOnEventsEnabled = True
Dim oRegenAllRules As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("iLogic.RegenAllRules")
oRegenAllRules.Execute2(True)
iLogicVb.DocumentUpdate
Wesley Crihfield
(Not an Autodesk Employee)
CattabianiI
What does "does not perform" mean?
if you add a MsgBox("foo") before RunRule do you get the message?
and if you add MsgBox(oComp.DisplayName)
Who did write this rule? Do you know what those lines mean?
oComp.DisplayName is the file name with extension by default, I hope you don't name your occurrences with file extension.
I'm pretty sure that doesn't work in Inventor 2019 either.
mcgyvr
Did you verify that the Tempo rule is in each part file?
WCrihfield
Also, I believe that it may be possible that not all ReferencedDocuments in every file are going to be "native" Inventor documents.
ReferencedDocuments.Item(1) is seen as "_Document", not just regular "Document".  If one of the ReferencedDocuments was some other type of document, it would throw an error.
Wesley Crihfield
Curtis_Waguespack
Hi @Anonymous
Welcome to the forum.
A couple of quick tips:
  • With Inventor 2019 and 2020 (maybe 2018? i can't recall).. you can use the ilogic Logger to report information as your rule runs.
  • For trouble shooting add Catch Ex as Exception and then return that to the ilogic Logger as in this example to show you what the Try/Catch issue is... see example below
Click the + sign as shown, and then select iLogic Log to bring up the logger
	Logger.Info(oComp.FullFileName)
	Try
		Logger.Info("Rule was run")
	Catch ex As Exception
		Logger.Error(ex.Message)
		Logger.Info("File Opened")
		Logger.Info("File Closed")
	End Try
Next
I hope this helps.
Curtis
Thanks everyone for your advice. It was helpful that made me understand the error, so I decided to solve it.
	Try
		'iLogicVb.RunRule(oComp.DisplayName & ":1", "Tempo")
iLogicVb.RunRule(oComp.DisplayName, "Tempo") Catch ThisApplication.Documents.Open(oComp.FullFileName) ThisApplication.Documents.Open(oComp.FullFileName).Close End Try Next
Thank you
