iLogic Delete suppressed features and un-used sketches in a multibody part
GKPByDesign
GKPByDesign
Can this be done with iLogic, I use sheet metal for most my parts. Only to delete features that are suppressed then to check again to delete sketches that are not used at all
WCrihfield
Yes. This is possible.  Below is a simple code for doing this.  However, if the suppressed feature has any consumed sketches, dependant featues / sketches, or dependant work features, it will likely throw an error.  If you wanted, you could include a line like "On Error Resume Next" just before the For Each line.  This will allow the code to continue to run when it encounters errors.  On the Delete line of code, you will notice three "False" three times.  This is where it answers the normal three questions it asks you when you delete a feature.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oFeats As PartFeatures = oCompDef.Features
For Each oFeat As PartFeature In oFeats
	If oFeat.Suppressed = True Then
		oFeat.Delete(False, False, False)
Next
I hope this helps.
If this solves your problem, or answers your question, pleas click 'Accept As Solution'.
Or if this helps you along the way to reaching your goal, please click 'Like'.
Wesley Crihfield
(Not an Autodesk Employee)
GKPByDesign
This looks correct, but how where would I write the error code you mention?
WCrihfield
Like this...
Next
Wesley Crihfield
