iLogic to create True/False User Parameter
I am trying to write an iLogic rule that enters a large set of User Parameters that are used in calculations and other iLogic Rules.  I have found how to do numerical, text and multi-value user parameters but I cannot find how to use iLogic to create a true/false user parameter.  Can anyone help me out here?  Thanks.
Ryan
Curtis_W
Hi rgitzlaff70,
I think this is what you're looking for (see the "Boolean" example):
http://forums.autodesk.com/t5/Inventor-Customization/Create-a-Boolean-Parameter/m-p/3161174#M36170
I hope this helps.
Curtis
Thanks, that worked great!
JorisSteurs1246
tried this code , does give a lot of errrors, probably too old for AI 2015 😞
