ilogic to convert circles to holes
FProcp
Message 1 of 73
FProcp
Does anyone know of an iLogic code that can convert circles to holes?
We receive plate models from others and the holes are drawn as circles and then extruded as through cuts.
I would like to be able to convert all circles in the plate (possibly under a certain diameter) to proper holes.
Has anyone done this before?
Franco
GMT +08:00
Replies (72)
Message 21 of 73
FProcp
This routine (by Jane) often seems to fail.
Could somebody please tell me why it doesn't always work?
It works sometimes and not other times.
Franco
GMT +08:00
Message 22 of 73
GeorgK
Great program. Is it possible to add countersunk holes?
Message 23 of 73
FProcp
Unfortunately No.
Not countersunk holes Smiley Sad
Franco
GMT +08:00
Message 24 of 73
Trying to run janes first code...I get an error on the last line... the actual hole creation..
oHole = doc.ComponentDefinition.Features.HoleFeatures.AddDrilledByThroughAllExtent(oPD,oSk.SketchCircles(1).Radius*2, partfeatureextentdirectionenum.kSymmetricExtentDirection)
anyone else have this issue?
cheers
Message 25 of 73
FProcp
The sample file that I sent Jane has Ø14 holes, Ø18 holes and Ø28 holes.
I think Janes program will only work with plate that contains only those three hole sizes.
Am I right Jane?
We need to change it to work with all hole sizes within a certain range.
Franco
GMT +08:00
Message 26 of 73
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @FProcp,
Try the following iLogic code for all hole sizes.
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim oSK As PlanarSketch
oSK = oDoc.ComponentDefinition.Sketches(1)
Dim objCol As ObjectCollection
objCol = ThisApplication.TransientObjects.CreateObjectCollection
'Store the large circles whose diameter are larger then 50mm
Dim oLarCircles As ObjectCollection
oLarCircles = ThisApplication.TransientObjects.CreateObjectCollection
For Each oskarc In oSK.SketchArcs
    objCol.Add(oskarc)
Next
For Each oskline In oSK.SketchLines
    objCol.Add (oskline)
Next
Dim oRadiusList As ArrayList = New ArrayList
Dim oCircle As SketchCircle
For Each oCircle In oSK.SketchCircles
	If oRadiusList.Contains(Math.Round(oCircle.Radius, 3)) = False Then
		oRadiusList.Add(Math.Round(oCircle.Radius, 3))
Next
Dim oCircleCol(oRadiusList.Count) As ObjectCollection
For i = 0 To oRadiusList.Count
    oCircleCol(i) = ThisApplication.TransientObjects.CreateObjectCollection
Next
For j = 0 To oRadiusList.Count - 1
		If Math.Round(oCircle.Radius, 3).ToString = oRadiusList.Item(j).ToString Then
			oCircleCol(j).Add(oCircle)
	Next
Next
Dim oP1 As Profile
oP1 = oSK.Profiles.AddForSolid(False, objCol)
Dim oD1 As FaceFeatureDefinition
oD1 = oDoc.ComponentDefinition.Features.FaceFeatures.CreateFaceFeatureDefinition(oP1)
'Create first face feature including the whole block
Dim oF1 As FaceFeature
oF1 = oDoc.ComponentDefinition.Features.FaceFeatures.Add(oD1)
'Create hole feature for the rest center point of the circles
Dim oTempCol As ObjectCollection
oTempCol = ThisApplication.TransientObjects.CreateObjectCollection
Dim oPD As HolePlacementDefinition
For i = 0 To oRadiusList.Count - 1
    oTempCol.Clear
    Dim dDiameter As Double
    For Each oCircle In oCircleCol(i)
        oTempCol.Add (oCircle.CenterSketchPoint)
    Next
    dDiameter = oCircleCol(i).Item(1).Radius * 2
    oPD = oDoc.ComponentDefinition.Features.HoleFeatures.CreateSketchPlacementDefinition(oTempCol)
    Call oDoc.ComponentDefinition.Features.HoleFeatures.AddDrilledByThroughAllExtent(oPD, dDiameter, kSymmetricExtentDirection)
Next
Please feel free to contact if there is any queries,
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 27 of 73
FProcp
Thanks, I will try soon.
Franco
GMT +08:00
Message 28 of 73
FProcp
The testing I've done so far has been great. It works every time.
Will test some more tomorrow.
Franco
GMT +08:00
Message 29 of 73
Chandra,
how easy is it to modify this for non sheet metal parts?
Message 30 of 73
FProcp
My requirement is for sheet metal and I couldn't think of an application where it would be useful outside of sheet metal.
I think it should work fine though.
Franco
GMT +08:00
Message 31 of 73
FProcp
How difficult would it be to place the hole diameter in the name of the hole feature to one decimal place?
For example re-name the Ø14.3 hole to "HoleD14.3".
Franco
GMT +08:00
Message 32 of 73
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @FProcp,
Try the following iLogic code to rename hole feature.
    objCol.Add(oskarc)
Next
Next
Next
Next
	Next
Next
Dim oP1 As Profile
    oTempCol.Clear
    Next
	dDiameter = Math.Round(dDiameter, 2)
    Dim oHole As HoleFeature
	oHole = oDoc.ComponentDefinition.Features.HoleFeatures.AddDrilledByThroughAllExtent(oPD, dDiameter, kSymmetricExtentDirection)
	oHole.Name = "HoleD" + dDiameter.ToString
Next
Please feel free to contact if there is any queries.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 33 of 73
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
Can you please provide sample non sheet metal parts? I will do feasibility study.
Please makes sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 34 of 73
FProcp
This works great.
But, the feature name is slightly wrong as the number needs to be multiplied by x10.
For example the feature "HoleD1.8" should be "Hole18" because it's a Ø18 hole.
Besides that it is excellent.
Franco
GMT +08:00
Message 35 of 73
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @FProcp,
Try this now.
    objCol.Add(oskarc)
Next
Next
Next
Next
	Next
Next
Dim oP1 As Profile
    oTempCol.Clear
    Next
	dDiameter = dDiameter * 10
oHole.Name = "HoleD" + dDiameter.ToString Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 36 of 73
FProcp
That is excellent but could we please show one decimal place?
Franco
GMT +08:00
Message 37 of 73
FProcp
I have attached a part file with just a sketch in it ready for processing.
Is this OK?
Franco
GMT +08:00
Message 38 of 73
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @FProcp,
Try the following iLogic code for PartDocument.
    objCol.Add(oskarc)
Next
Next
Next
Next
	Next
Next
Dim oP1 As Profile
oD1 = oDoc.ComponentDefinition.Features.ExtrudeFeatures.CreateExtrudeDefinition(oP1, kNewBodyOperation)
oD1.SetDistanceExtent("6 mm", kSymmetricExtentDirection)
oF2 = oDoc.ComponentDefinition.Features.ExtrudeFeatures.Add(oD1)
    oTempCol.Clear
    Next
	dDiameter = Math.Round(dDiameter, 1)
Next
Below iLogic code strictly for Sheet metal part. Because, FaceFeature is available only for sheet metal document.
    objCol.Add(oskarc)
Next
Next
Next
Next
	Next
Next
Dim oP1 As Profile
    oTempCol.Clear
    Next
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 39 of 73
FProcp
I've tried both the sheet metal version and the part version.
They both work really well.
The only issue is that the the holes are rounded off to zero decimal places.
The Ø14.3 circle becomes a Ø14 hole.
I could go through and fix these all up manually later but it would be nice it was correct with the code.
Thank you so much for your assistance.
Franco
GMT +08:00
Message 40 of 73
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @FProcp,
In both iLogic code, change from dDiameter = Math.Round(dDiameter, 1) to dDiameter = Math.Round(dDiameter, 2). It will work.
If solves problem, click on "Accept as solution" / give a "kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
