Hi @FProcp,
Try the following iLogic code for PartDocument.
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim oSK As PlanarSketch
oSK = oDoc.ComponentDefinition.Sketches(1)
Dim objCol As ObjectCollection
objCol = ThisApplication.TransientObjects.CreateObjectCollection
For Each oskarc In oSK.SketchArcs
objCol.Add(oskarc)
Next
For Each oskline In oSK.SketchLines
objCol.Add (oskline)
Next
Dim oRadiusList As ArrayList = New ArrayList
Dim oCircle As SketchCircle
For Each oCircle In oSK.SketchCircles
If oRadiusList.Contains(Math.Round(oCircle.Radius, 3)) = False Then
oRadiusList.Add(Math.Round(oCircle.Radius, 3))
End If
Next
Dim oCircleCol(oRadiusList.Count) As ObjectCollection
For i = 0 To oRadiusList.Count
oCircleCol(i) = ThisApplication.TransientObjects.CreateObjectCollection
Next
For j = 0 To oRadiusList.Count - 1
If Math.Round(oCircle.Radius, 3).ToString = oRadiusList.Item(j).ToString Then
oCircleCol(j).Add(oCircle)
End If
Next
Next
Dim oP1 As Profile
oP1 = oSK.Profiles.AddForSolid(False, objCol)
oD1 = oDoc.ComponentDefinition.Features.ExtrudeFeatures.CreateExtrudeDefinition(oP1, kNewBodyOperation)
oD1.SetDistanceExtent("6 mm", kSymmetricExtentDirection)
oF2 = oDoc.ComponentDefinition.Features.ExtrudeFeatures.Add(oD1)
'Create hole feature for the rest center point of the circles
Dim oTempCol As ObjectCollection
oTempCol = ThisApplication.TransientObjects.CreateObjectCollection
Dim oPD As HolePlacementDefinition
For i = 0 To oRadiusList.Count - 1
oTempCol.Clear
Dim dDiameter As Double
For Each oCircle In oCircleCol(i)
oTempCol.Add (oCircle.CenterSketchPoint)
Next
dDiameter = oCircleCol(i).Item(1).Radius * 2
dDiameter = Math.Round(dDiameter, 1)
oPD = oDoc.ComponentDefinition.Features.HoleFeatures.CreateSketchPlacementDefinition(oTempCol)
Dim oHole As HoleFeature
oHole = oDoc.ComponentDefinition.Features.HoleFeatures.AddDrilledByThroughAllExtent(oPD, dDiameter, kSymmetricExtentDirection)
dDiameter = dDiameter * 10
oHole.Name = "HoleD" + dDiameter.ToString
Next
Below iLogic code strictly for Sheet metal part. Because, FaceFeature is available only for sheet metal document.
'Store the large circles whose diameter are larger then 50mm
Dim oLarCircles As ObjectCollection
oLarCircles = ThisApplication.TransientObjects.CreateObjectCollection
objCol.Add(oskarc)
Next
Next
End If
Next
Next
End If
Next
Next
Dim oP1 As Profile
Dim oD1 As FaceFeatureDefinition
oD1 = oDoc.ComponentDefinition.Features.FaceFeatures.CreateFaceFeatureDefinition(oP1)
'Create first face feature including the whole block
Dim oF1 As FaceFeature
oF1 = oDoc.ComponentDefinition.Features.FaceFeatures.Add(oD1)
oTempCol.Clear
Next
Next
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
