iLogic to Change Revision Table Date Format
Dianna_Harding
Message 1 of 9
Dianna_Harding
I've searched and found posts  that were close, but not quite. Not sure it's possible after what I've read, but I'm not the most savvy with iLogic.
Ref posts:
Read revision
Change Value
Convert String
What I need is a code similar to the referenced links that will read every row's date and convert it to MM/dd/yy. So if the date is: 7/11/2009, it needs to be converted to 07/11/09 or 7-11-09 -->07/11/09
Any help would be greatly appreciated.
Accepted solutions (3)
Replies (8)
Message 2 of 9
C_Haines_ENG
This should work:
Sub Main
	Dim oDoc As DrawingDocument = ThisDoc.Document
	Dim oSheet As Sheet = oDoc.ActiveSheet
	Dim oRevTable As RevisionTable = oSheet.RevisionTables(1)
	For i = 1 To oRevTable.RevisionTableRows.Count
		Dim oRevDate = oRevTable.RevisionTableRows(i).Item("DATE")
		Dim oMonth As Integer = Split(oRevDate.Text,"/")(0)
		Dim oDay As Integer = Split(oRevDate.Text,"/")(1)
		Dim oYear As Integer = Split(oRevDate.Text, "/")(2)
		oRevDate.Text = oMonth.ToString("D2") & "/" & oDay.ToString("D2") & "/" & Right(oYear, 2)
	Next
End Sub
Message 3 of 9
Dianna_Harding
Thank you! This almost works, but it doesn't like the date formats with "-"  such as 6-19-2025.
System.InvalidCastException: Conversion from string "3-20-13" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format.
at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger(String Value)
--- End of inner exception stack trace ---
at ThisRule.Main() in external rule: _Date Format:line 10
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 4 of 9
C_Haines_ENG
How many different formats of dates do you have?
Message 5 of 9
Dianna_Harding
I think the two. I'll try a Try--Catch statement to check for the dash and see if that works, but the rest of it is perfect. Thank you!
Message 6 of 9
C_Haines_ENG
We can just compensate for "wildcards" :
Sub Main
	'ADD WILDCARD STRINGS TO CONVERT DATE FORMATS
	Dim oWildCards As New List(Of String) : oWildCards.AddRange({"-", "_" })
		Dim oRevDate As RevisionTableCell = oRevTable.RevisionTableRows(i).Item("DATE")
		Dim oRevDateText As String = oRevDate.Text
		For Each oWildCard As String In oWildCards
			oRevDateText = Replace(oRevDateText, oWildCard, "/")
		Next
		Dim oMonth As Integer = Split(oRevDateText, "/")(0)
		Dim oDay As Integer = Split(oRevDateText, "/")(1)
		Dim oYear As Integer = Split(oRevDateText, "/")(2)
	Next
End Sub
Message 7 of 9
Dianna_Harding
Worked perfect, thank you!
Message 8 of 9
Dianna_Harding
Stress testing this and noticed that if the code is run more than once, it shortens any year converted to start with a zero to one digit. Is there a way to keep the zero?
Message 9 of 9
C_Haines_ENG
I should have thought about that. Try this:
Sub Main
		Next
		Dim oYear As Integer = Right(Split(oRevDateText, "/")(2), 2)
		oRevDate.Text = oMonth.ToString("D2") & "/" & oDay.ToString("D2") & "/" & oYear.ToString("D2")
	Next
End Sub
