iLogic Write to Excel
layochim
Message 1 of 8
layochim
Is there a good way to pull parameters from an IAM to drop into Cells within an Excel Spreadsheet and pull from that same spreadsheet, values to be sent back into Inventor?
Replies (7)
Message 2 of 8
WCrihfield
Yes, sort of.  Which 'way' would be best for accomplishing something like that depends on all the little details of the task, which you have not mentioned yet.  There are so many questions that could be asked here that is difficult to know where to start, because this may be a relatively simple task, or it may be a very complex task, depending on the details, and exactly how you want everything to work, and exactly how you want to specify which ones, coming from which source, should be going to which exact destination, and when, and how the whole process should be initiated.  If any pop-up prompts or dialogs would be needed, or if certain custom information would need to be 'hard-coded' into the code, verses using manual interactions, and so on.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 8
layochim
Currently I've figured out how to populate cells in an excel using iLogic.  Once this happens Excel generates a value from those and that value is what I'm trying to push back into inventor.  This is for a costing spreadsheet, if that helps.
Message 4 of 8
layochim
Please disregard, i've figured it out!  Thanks.
Message 5 of 8
C_Haines_ENG
Out of curiosity, which method did you end up using?
Message 6 of 8
layochim
Below is the code I put together, very basic and elementary code, I'm new to iLogic.  After modifying a parameter and running the code, I receive a RunTime error.  Which I've attached.
Turns out, I don't need to do any iLogic with Inventor, this was intended for another software which can read directly from Excel.
Sub Pricing()
xlsPath = "C:\Users\Lyle\OneDrive - SCR Solutions\Documents\ConfiguratorPricing.xlsx"
GoExcel.CellValue(xlsPath, "Costing", "B10") = BELTLENGTH
GoExcel.CellValue(xlsPath, "Costing", "B11") = TOB
GoExcel.CellValue(xlsPath, "Costing", "B12") = TOB
GoExcel.CellValue(xlsPath, "Costing", "B9") = BeltWidth
Total_Cost = GoExcel.CellValue(xlsPath, "Costing", "B6")
GoExcel.Save
GoExcel.DisplayAlerts = False
End Sub
Message 7 of 8
C_Haines_ENG
Well if you ever want to fix the Runtime error, let me know.
Message 8 of 8
layochim
That'd be great! I'd like to get this fixed just so I've got something to use on the side and for future projects.
