ilogic to change field text in a sketched symbol
DeepshipEngineering
Message 1 of 17
DeepshipEngineering
I have tried a few things but this seems a bit beyond me, does anyone have some code I could look at to change the value of a prompted entry in a sketched symbol? Inventor 2023
Replies (16)
Message 2 of 17
A.Acheson
Hi @DeepshipEngineering
@This question is better suited on the Ilogic forum but here is a start point. See this article here on setting the printed entry of Symbol 1.
This is the ilogic code in that article.
' Set the value for the first sketched symbol
' on the current sheet
Dim oSS As SketchedSymbol
oSS = ActiveSheet.Sheet.SketchedSymbols(1)
Dim oTB As TextBox
For Each oTB In oSS.Definition.Sketch.TextBoxes
  If oTB.Text = "<MyPrompt>" Then
    Call oSS.SetPromptResultText(oTB, "NewValue")
  End If
Next
If you want to find a specific symbol then you can directly reference the symbol object by first looping through all symbols and query the name with an if statement.
' Find the sketch symbol by name by looping through all symbols
For Each oSS As SketchedSymbol In ActiveSheet.Sheet.SketchedSymbols(1)
  If oSS.Name = "FindMe" Then
    MessageBox.Show(oSS.Name, “Found Symbol”)
    ‘Do something now with oSS object
  End If
Next
Regards
Alan
Message 3 of 17
DeepshipEngineering
Thanks but I cant seem to get it to work, could you attach a sketched symbol it works on so I can see where I am going wrong?
Message 4 of 17
A.Acheson
It sounds like your Property Field name is not matching.
Regards
Alan
Message 5 of 17
DeepshipEngineering
I think they are correct, (the only thing is the brackets <> but I have tried both ways) Tried a new symbol with your inputs but still no joy.
Can you send a symbol that its working with?
Message 6 of 17
A.Acheson
The brackets are just the automatically applied formatting. if your Property Field name has none type the text string exactly. Can you share the error message your getting? Can you share images of your symbol prompt box when you manually go to fill it in? Can you share the modified code you have tried.
Regards
Alan
Message 7 of 17
jnowel
this "(1)" is the likely cause of the error.
Message 8 of 17
DeepshipEngineering
What does that 1 do?
Message 9 of 17
jnowel
 Sets oSS as the first item in the SketchSymbols collection.
Removing the (1) makes you to loop thru all the symbols.
I believe the previous post has it as a typo and meant it like this
  End If
Next
Message 10 of 17
DeepshipEngineering
That works to find my sketched symbol, how do I then change the prompted entry? thanks
Message 11 of 17
jnowel
Combined the posted code earlier.
Should look like this
edit: commented out Exit for
edit2: should be working now
For Each oSS In ActiveSheet.Sheet.SketchedSymbols
	'    MessageBox.Show(oSS.Name, “Found Symbol”)
	'    Do something Now With oSS Object
	'Map you prompted text value as newValue
	Dim newValue As String
	newValue = "map your value here" 'change to suit
	'Scan all textbox then change if match
	Dim oTB As Object
			Call oSS.SetPromptResultText(oTB, newValue)
		End If
	Next
	End If
Next
Message 12 of 17
DeepshipEngineering
this is the error popping up
Error on Line 14 : 'TextBox' is ambiguous, imported from the namespaces or types 'Inventor, System.Windows.Forms'.
Error on Line 15 : 'oSS' is not declared. It may be inaccessible due to its protection level.
Message 13 of 17
jnowel
oops. check edit2 above
Message 14 of 17
DeepshipEngineering
Perfect...  I am going to try and and change the "map your value here" to a pop up message text input box unless you have a snippet you can throw in easily?
Im not a programmer but find with a mixture of very welcome help from the forums and a bit of ChatGPT I can muddle through most stuff
Message 15 of 17
jnowel
newValue = InputBox("Prompt", "Title", "Default Entry")
Message 16 of 17
DeepshipEngineering
@jnowel @A.Acheson
Thank you so much for your help, got it doing exactly what I wanted
Message 17 of 17
jnowel
A different version resulting to a different behavior
'This version asks the newValue once and will be used to all found sketchedsymbol matching the criteria
'Previous version asks everytime the oSS is found, so you can enter a different value (if you just change the newValue inside the for loop
newValue = InputBox("Prompt", "Title", "Default Entry") 'change to suit
		Dim oTB As Object
			End If
		Next
	End If
Next
