Hey forum,
I have two patterns and I am trying to add one pattern inside the other but I am unsure how to do this with iLogic. I think I have to make an object collection of the pattern that needs to be patterned again ("Pattern Two").
Here's how I've approached it so far:
Dim oDoc As Document = ThisApplication.ActiveDocument Dim oAsmCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition Dim oOccPattern1 As OccurrencePattern Dim oOccPattern2 As OccurrencePattern Dim oObjCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection Dim FirstPattern As String = "Pattern One" Dim SecondPattern As String = "Pattern Two" 'add second pattern inside first pattern For Each oOccPattern1 In oAsmCompDef.OccurrencePatterns If oOccPattern1.Name = FirstPattern Then 'looks for the first pattern inside the assembly For Each oOccPattern2 In oAsmCompDef.OccurrencePatterns If oOccPattern2.Name = SecondPattern Then 'looks for the second pattern inside the assembly oObjCol.Add(oOccPattern2) 'adds the second pattern into a collection oOccPattern1.ParentComponents.Add(oObjCol) End If Next
E End If Next
Any help is greatly appreciated!
Felix
