Assembly - change derived source part ilogic
pbartosinski
pbartosinski
I have some problem. I have an assembly:
MAIN.iam:
skeleton.itp
partA.ipt (derived from skeleton.itp)
partB.ipt (derived from skeleton.itp)
partC.itp (derived from skeleton.itp)
I know when I change filename of skeleton.itp then when i open MAIN.iam inventor asks about source file.
Is there any iLogic to change skeleton to other part and parent in partA, partB, partC??
johnsonshiue
Hi! Just raise some caution here. There is a reason why Derive source cannot be changed. Inventor inter-file associativity is largely based on file document ID. If some how the new source file has a different doc ID than the existing source file, all the downstream features and derived objects will fail. You will need to re-derive the new source, which is not much different than creating from scratch.
Many thanks!
Software Test Engineer
andrewiv
I do have an iLogic rule to change the source part on a derived part.  But it does check to make sure that the two are similar and I'm at home right now, but I'll get it for you tomorrow.
Andrew In’t Veld
Designer / CAD Administrator
andrewiv
Here is my rule to replace derived reference.  I can't take complete credit for it though, as I got it off of a google search a couple of years ago.
Option Strict On
Sub Main
  topDoc = ThisApplication.ActiveDocument
  Replace()
End Sub
Private topDoc As Document
Public Sub Replace()
	If (Not LevelOfDetailIsMaster()) Then Return
	Dim docToReplace As Document = FindDocToReplace()
	If (docToReplace Is Nothing) Then Return
	Dim replacementFileName As String = SelectReplacementFilename(docToReplace.DisplayName)
	If (String.IsNullOrEmpty(replacementFileName)) Then Return
	If (String.Equals(docToReplace.FullFileName, replacementFileName, StringComparison.OrdinalIgnoreCase)) Then Return
	Dim replacementPart As Document = ThisApplication.Documents.Open(replacementFileName, False)
	Dim doReplace As Boolean = True
	If (replacementPart.InternalName <> docToReplace.InternalName) Then
		MessageBox.Show("The replacement part (" & replacementPart.DisplayName & ") does not seem to be closely related to the original part, so it cannot be used.", _
		"Base Part Replacer", MessageBoxButtons.OK, MessageBoxIcon.Warning)
		doReplace = False
	replacementPart.ReleaseReference()
	If (Not doReplace) Then Return
	Dim fileNameToReplace As String = docToReplace.FullFileName
	ReplaceReferences(topDoc, fileNameToReplace, replacementFileName)
	topDoc.Update()
End Sub
Function FindDocToReplace() As Document
	Dim basePartList As New List(Of Document)
	If (topDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
		AddBaseParts(basePartList, topDoc)
	Else
		For Each refDoc As Inventor.Document In topDoc.AllReferencedDocuments
			If (refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
				AddBaseParts(basePartList, refDoc)
		Next
	If (basePartList.Count = 0) Then
		MessageBox.Show("No base parts were found in the document: " & topDoc.DisplayName, "Base Part Replacer")
	ElseIf (basePartList.Count = 1) Then
		Return basePartList(0)
	Else
		Dim partNameList As New List(Of String)
		For Each baseDoc As Document In basePartList
			partNameList.Add(baseDoc.DisplayName)
		Next
		Dim selectedName As String = InputListBox("Select the part to replace", partNameList, partNameList(0), "Replace Part", "Parts").ToString()
		Dim selectedIndex As Integer = partNameList.IndexOf(selectedName)
		Return basePartList(selectedIndex)
	Return Nothing
End Function
Sub AddBaseParts(ByVal basePartList As List(Of Document), ByVal doc As Document)
	For Each refDoc As Document In doc.ReferencedDocuments
		If (refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject AndAlso Not IsiPartMember(refDoc)) Then
			If (Not basePartList.Contains(refDoc)) Then
				basePartList.Add(refDoc)
	Next
End Sub
Function IsiPartMember(ByVal doc As Document) As Boolean
	If (doc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then Return False
	Dim partDoc As PartDocument = DirectCast(doc, PartDocument)
	Return partDoc.ComponentDefinition.IsiPartMember
End Function
Function SelectReplacementFilename(ByVal filenameToReplace As String) As String
	Dim oFileDlg As Inventor.FileDialog = Nothing
	ThisApplication.CreateFileDialog(oFileDlg)
	oFileDlg.Filter = "Part Files (*.ipt)|*.ipt"
	oFileDlg.DialogTitle = "Replace " & filenameToReplace
	'oFileDlg.InitialDirectory = ThisDoc.Path
	oFileDlg.CancelError = False
	Try
		oFileDlg.ShowOpen()
		Return oFileDlg.FileName
	Catch
	End Try
	Return String.Empty
End Function
Sub ReplaceReferences(ByVal doc As Document, ByVal fileNameToReplace As String, ByVal replacementFileName As String)
	ReplaceReferencesInOneDoc(doc, fileNameToReplace, replacementFileName)
	For Each subDoc As Document In doc.AllReferencedDocuments
		If (String.Equals(subDoc.FullFileName, fileNameToReplace, StringComparison.OrdinalIgnoreCase) OrElse _
		 String.Equals(subDoc.FullFileName, replacementFileName, StringComparison.OrdinalIgnoreCase)) Then
			Continue For
		ReplaceReferencesInOneDoc(subDoc, fileNameToReplace, replacementFileName)
	Next
End Sub
Sub ReplaceReferencesInOneDoc(ByVal doc As Document, ByVal fileNameToReplace As String, ByVal replacementFileName As String)
	For Each docDesc As DocumentDescriptor In doc.ReferencedDocumentDescriptors
		Dim desc As FileDescriptor = docDesc.ReferencedFileDescriptor
		If (desc.ReferenceMissing) Then Continue For
		Console.WriteLine("Referenced RelativeFileName = " & desc.RelativeFileName)
		Trace.WriteLine("Referenced RelativeFileName = " & desc.RelativeFileName)
		If (String.Equals(desc.FullFileName, fileNameToReplace, StringComparison.OrdinalIgnoreCase)) Then
			desc.ReplaceReference(replacementFileName)
			Exit For
	Next
End Sub
Function LevelOfDetailIsMaster() As Boolean
	Dim assemDoc As AssemblyDocument = TryCast(topDoc, AssemblyDocument)
	If (assemDoc Is Nothing) Then Return True
	Dim repMgr As RepresentationsManager = assemDoc.ComponentDefinition.RepresentationsManager
	Dim lodType As LevelOfDetailEnum = repMgr.ActiveLevelOfDetailRepresentation.LevelOfDetail
	If (lodType <> LevelOfDetailEnum.kMasterLevelOfDetail) Then
		MessageBox.Show("This rule can only be run in the Master Level of Detail.", "Base Part Replacer")
		Return False
	Return True
End Function
Andrew In’t Veld
