Ilogic suppressing every n-th element in pattern
plesTTGPA
plesTTGPA
I'm trying to divide a pattern into sections by suppressing every n-th element , but when changing parameter "a" I get this error message.
The rule I use:
'Suppresing n-th element
'a - number of elements in pattern
'b - number of sections
Dim n As Integer = a/b
Dim oDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPattern As OccurrencePattern = oDef.OccurrencePatterns.Item("Component Pattern 1:1")
For Each oElement As OccurrencePatternElement In oPattern.OccurrencePatternElements
		oElement.Suppressed = False
	If oElement.Index Mod n = 0 Then
		oElement.Suppressed = True
	End If
Next
Curtis_Waguespack
Hi @plesTTGPA
I think the issue is that if you reduce the number of elements in the pattern ( example: from 41 to 40) the For each loop is still trying to suppress element 41, which doesn't exist.
Adding a document update before the loop should resolve this.
I hope this helps.
Curtis
InventorVb.DocumentUpdate()
	End If
Next
