Count parameter as 001 -> 002 -> etc.
L.Greft
L.Greft
I have a parameter called "QUANTITY" and want a messagebox to count to the value of the parameter.
The code I have now counts as 1 -> 2 -> 3 -> etc., but I want to count it as 001 -> 002 -> 003 -> etc..
Below you can find the code I use now, is it possible to edit the code so it does count as 001? The QTY_index should always have 3 characters, so if the QUANTITY is 54 the QTY_index should be 054.
Dim FileName As String
For QTY_index As Integer = 1 To QUANTITY
	FileName = "PartInformation_" & QTY_index
	MessageBox.Show(FileName, "FileName")
Next
*Edit: I just thought about using this (below), but if someone has a better idea please let me know : )
Dim Help As String
	If QUANTITY>= 0 And QUANTITY< 10 Then
		Help = "00"
	ElseIf QUANTITY>= 10 And QUANTITY< 100 Then
		Help = "0"
	Else
		Help = ""
	FileName = "PartInformation_" & Help & QTY_index
Next
Check out my ideas: https://autode.sk/2TKe6LH
fullevent
Hi @L.Greft,
try this (untested)
	FileName = "PartInformation_" & Format(QTY_index, "000")
Next
That should work as wanted.
Best regards,
Aleksandar Krstic
Produkt- und Projektmanager
L.Greft
Thank you @fullevent, this works great!
