Ilogic subassembly Model State change
a_burggraafUPR9E
a_burggraafUPR9E
I have been fiddling around for a long time to find a way in iLogic, when you have a large assembly with lots of subassemblies, to change the model states of these subassemblies from the overlying assembly. However i have not yet come up with a way to do this.
kacper.suchomski
Hi
This question is very general.
There are many methods and ways, and their selection depends on the goal (specific, not rhetorical).
If the model state names are the same, this can be done with one command (Merge Model States in the Productivity panel). You don't need iLogic for this. The condition is to create an analogous list in the assembly file.
In the case of iLogic, the following code should be used.
Of course, this must be conditioned by some parameter.
Component.ActiveModelState("Part1:1") = "ModelStateName"
Kacper Suchomski
