Repost: Ref parameter from ipt to iam
SpokenEarth
SpokenEarth
Hi forum, I have a part with a ref parameter and a code which allow me to toggle between int and ext diameter and I want to access it / make editable from iam.
Can someone help me please?
I have enclosed files and the code, ver 2024
Dim oPDoc As PartDocument = ThisDoc.Document
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oSketch As PlanarSketch = oPDef.Sketches.Item("STORAGE TANK BODY")
Dim oDims As DimensionConstraints = oSketch.DimensionConstraints
Dim oHeightDim As DimensionConstraint
Dim oAngleDim As DimensionConstraint
For Each oDim As DimensionConstraint In oDims
If oDim.Parameter.Name = "STORAGE_TANK_EXTERNAL_DIA" Then
oHeightDim = oDim
ElseIf oDim.Parameter.Name = "STORAGE_TANK_INTERNAL_DIA" Then
oAngleDim = oDim
Next
If oHeightDim.Driven Then
	oAngleDim.Driven = True
	oHeightDim.Driven = False
Else
	oHeightDim.Driven = True
	oAngleDim.Driven = False
marcin_otręba
Editable for selected part or all parts in that assembly ?
if selected part then you can try using this:
Sub main()
set_par(ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "choose part").definition.document)
End Sub
Sub set_par(oPDoc As PartDocument)
On Error Resume Next
'	Dim oPDoc As PartDocument = ThisDoc.Document
oHeightDim = oDim
oAngleDim = oDim
Next
Else
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
SpokenEarth
Hi, just a part.....well for now.
Your code works perfect! thanks for helping me out.
Have a pleasant weekend
