iLogic Sub Assembly
iLogic Sub Assembly
Cosmin_V
Message 1 of 8
iLogic Sub Assembly
Cosmin_V
Hi
I have a Assembly whit some Sub Assemblys in.
Because I use Vault and I have to change the name of Assembly when I do copy design, I use this: in Assembly
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oSilo1 As ComponentOccurrence = oDef.Occurrences.Item(1)
Dim oSilo2 As ComponentOccurrence = oDef.Occurrences.Item(2)
Dim oSilo3 As ComponentOccurrence = oDef.Occurrences.Item(3)
Dim oSilo4 As ComponentOccurrence = oDef.Occurrences.Item(4)
Dim oSilo5 As ComponentOccurrence = oDef.Occurrences.Item(5)
Dim oSilo6 As ComponentOccurrence = oDef.Occurrences.Item(6)
Dim oSilo7 As ComponentOccurrence = oDef.Occurrences.Item(7)
Dim oSilo8 As ComponentOccurrence = oDef.Occurrences.Item(8)
Dim oSilo9 As ComponentOccurrence = oDef.Occurrences.Item(9)
Dim oSilo10 As ComponentOccurrence = oDef.Occurrences.Item(10)
Dim oSilo11 As ComponentOccurrence = oDef.Occurrences.Item(11)
Dim oSilo12 As ComponentOccurrence = oDef.Occurrences.Item(12)
and this in Sub Assembly:
Dim oFoundation As ComponentOccurrence = oDef.Occurrences.Item(1)
Dim oSilo As ComponentOccurrence = oDef.Occurrences.Item(2)
Dim oConv As ComponentOccurrence = oDef.Occurrences.Item(3)
It is ok is work ok but I have a problem when I want to call a part from Sub Assembly
I don't know how the code should be.
like this is not working:......
If SUPRESS_SILO="Yes" Then
Component.IsActive(MakePath(oSilo1.Name, oSilo.Name))=True
End If
Somebody know how this rule shout be?
Many Thanks!
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@Cosmin_V,
To suppress the part inside subassembly, try below changes.
Component.IsActive(MakePath(oSilo1.Name, oSilo.Name))= false
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
Cosmin_V
Hi
Component.IsActive(MakePath(oSilo1.Name, oSilo.Name))=False
ElseIf SUPRESS_SILO="No" Then
End If
Message 4 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@Cosmin_V,
Please provide non confidential and steps to reproduce the error.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 8
Cosmin_V
Hi
I am not allowed to share the original one, and I do something quick and same as the original.
I hope is helps.
Many Thanks
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@Cosmin_V,
Thanks for data to test,
In attached data, complete sub assembly is not present and unable to reproduce the error. Original files are not required to test. But simulate the same hierarchy in assembly.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 8
Cosmin_V
Hi
Sorry...I was i a hurry. See now
Many Thanks!
Message 8 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@Cosmin_V,
Try below iLogic code to suppress part of subassembly.
Dim oSilo As ComponentOccurrence = oSilo1.SubOccurrences.Item(2)
MultiValue.SetList("Type", "S120", "S140", "S160")
If Supress_Silo="Yes" Then
Call oSilo.Suppress
ElseIf Supress_Silo="No" Then
Call oSilo.Unsuppress()
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
