Ilogic: Sketch/ Sketch Dimension visibility for part inside a assemblie
ward_hanotGZU45
ward_hanotGZU45
Hello everybody,
Is there a way to use an ilogic code to turn a sketch or sketch dimension on that is used for a feature in a part?
I have a assembly with 3 parts. On one part i have several features (extrude cuts).
I use a form to unsuppres these feature and to change the dimension in the assemblie on the part level.
I would like to see the sketch or sketch dimensions for these features when they are unsuppresed.
Par example: when DeurZicht1 is true the sketch Z1DO should become visible. Z1DOML is the dimension in the sketch Z1DO witch positions the Dooropening.
Since there a several features, turning them all on or off at once is not prefferd.
I suppose this is possible but I haven't found a code yet to accomplishe this.
BM_Ashraf
Hi @ward_hanotGZU45
I Think using Inventor API is a better way to get what you are looking for.
Please check the names!
At the end you will get the sketch and the parameter. You can turn the visibilty of the sketch on/off
Dim oASMDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oASMCDEF As AssemblyComponentDefinition = oASMDoc.ComponentDefinition
'Dim oCC As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select Part Doc")
Dim oRefDoc As PartDocument
For Each oCC In oASMCDEF.Occurrences
	If oCC.Name = "Cabine-Start:1 (325)" Then 'Please re-check if the name is correct!!!
		oRefDoc = oCC.ReferencedDocumentDescriptor.ReferencedDocument
		Exit For
	End If
Next
If oRefDoc Is Nothing Then
	MsgBox("Couldn't find the file: " & "Cabine-Start:1 (325)" )
	Exit Sub
End If
Dim oPCDEF As PartComponentDefinition = oRefDoc.ComponentDefinition
Dim oZ1DOE As PlanarSketch
Try
	oZ1DOE  = oPCDEF.Sketches.Item("Z1DO") 'Please re-check if the name is correct!!!
	oZ1DOE .Visible = True
Catch
	MsgBox("Couldn't find the Sketch: " & "Z1DO")
	Exit Sub
End Try
Dim oParameter As Parameter
Try
	oParameter = oPCDEF.Parameters.Item("Z1DOML") 'Please re-check if the name is correct!!!
Catch
	MsgBox("Couldn't find the Parameter: " & "Z1DOML")
	Exit Sub
End Try
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
ward_hanotGZU45
Sorry for the late reply, but this doesn't seem to work, I changed the names for Cabine-start:1 (325) to Cabine-start:1 because it coulnd't find it. But then it still doens't work.
Could it be a problem that the sketch is at a part level and not at an assembly level?
BM_Ashraf
To save the time, please upload test files.
Blue Mech
