Ilogic save problem
Ilogic save problem
tegstette
Ilogic save problem
tegstette
HelloSmiley Happy
I am a beginner at ilogic and I am playing around with some ilogic rules, but cannot seem to figure this one out... I need a simple ilogic rule that does something like this:
  1. If the file is not yet saved (typical for new parts from a template) – do nothing
  2. If the file is saved (has a filename) and BOM-quantity is «Each» - do nothing
  3. If the file is saved (has a filename) and BOM-quantity is not «Each» - set BOM-quantity to «Each»
'set the Base Quantity to the parameter Each
  1. ThisDoc.Document.ComponentDefinition.BOMQuantity.SetBaseQuantity(BOMQuantityTypeEnum.kEachBOMQuantity)
Is there anyone that can help me out?
Best regards
TG
Autodesk Inventor/Vault Professional 2021
xiaodong_liang
Autodesk Support
Autodesk Support
Please refer to the code below. Hope it helps you.
doc = ThisDoc.Document
If doc.FileSaveCounter = 0 Then
  ' If the file is not yet saved (typical for new parts from a template) – do nothing
  MsgBox("The Document has not been saved!")
Else
    Dim oAssDef As AssemblyComponentDefinition
    oAssDef = doc.ComponentDefinition
    Dim oBOMType As BOMQuantityTypeEnum
    oAssDef.BOMQuantity.GetBaseQuantity (oBOMType)
    If oBOMType = BOMQuantityTypeEnum.kEachBOMQuantity Then
     'If the file is saved (has a filename) and BOM-quantity is ?Each? - do nothing
      MsgBox("The BOM Quantity type is Each!")
    Else
     'If the file is saved (has a filename) and BOM-quantity is not ?Each? - set BOM-quantity to ?Each?
     MsgBox("The BOM Quantity type is NOT Each!")
      oAssDef.BOMQuantity.SetBaseQuantity (BOMQuantityTypeEnum.kEachBOMQuantity)
    End If
End If
