Ilogic rule to set a part to disable/enable by keyword
ILU
ILU
I am new to ilogic but i am pretty sure that is possible
I am looking for a rule to set to disable a part if text parameter is set to No/ Yes.
we are using in all assemblies as a prefix a project number and we have few assemblies where same part it is used.
For example P12345_part(3):1
I am looking for a piece of code to find to find the "part(3)" into assembly and set it to disable.
Thanks in advance
RO-ENG
The code below will probably work for you, it will look trough each component and check if the name contains "part(3)" if it does it will suppress the part if the parameter "EnablePart" is set to No, and it will unsuppres if it is set to Yes, when the parameter is on neither yes or no, it will also suppress te feature. Important to note is that you would have to make a custom level of detail for the code to work though
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
	If (oOccurrence.Name.Contains("part(3)")) Then
		Dim Enabled As Boolean = (EnablePart = "Yes")
		Component.IsActive(oOccurrence.Name) = Enabled
Next
Mirtchii
Hi ILU,
You can try using this. No need to make a new Level of detail too.
First, create a true/false parameter named "part 3" then paste the below code to the coding space.
ThisAssembly.BeginManage()
If (part3) Then
ThisAssembly.EndManage()
*****: You have to look at the Model tab in Rule window, right click on the part that you want ( in this case P12345_part(3)) and choose "Capture current state" to finish the code.
Hope you can solve your problem.
ILU
Thanks @RO-ENG
the code worked flawlessly. Finaly mine rule looked like below
	If oOccurrence.Name.Contains("keyword") Then
		Dim Part As Boolean = (Parameter = "YES")
Next
oPart = Component.InventorComponent(oOccurrence.Name)
If Parameter = "YES" Then
	oPart.Visible= True
	oPart.Enabled = True
	Else
		oPart.Visible = False
		oPart.Enabled = False
iLogicVb.UpdateWhenDone = True
