Automate sub-layout creation
I'm looking to automate our sub-layout creation in Factory. We make large layout for the industry and we have a ERP structure that we build our layouts around. But, the prepositional work in creating these sub-layouts is very time consuming.
The filename for the top level is always a unique 5-digit quotation number, after that a prefix is added
My idea is:
Once you have created your top level Factory layout, dubbed that 12345 (i.e.) and saved it, you would run a rule called "create sub-layouts". The rule would then look at the filename for the top layout and add the prefix
I have attached picture, which hopefully explains it better
CattabianiI
It's all about creating, placing and saving an assembly starting from the leaf:
' Get the layout document name
' Create the assembly leaf and save it with the layout_document_name + "01-01-00001"
' Create the parent assembly, place the previous one and save it according to your naming rule.
' And so on
If I understood properly they are all quite simple and well documented tasks.
