Can ilogic check if my part is a multi-body part?
b_ruijter
b_ruijter
We use a rule that makes flat-pattens if a part is a sheet metal part. But a multi-body part can not make flat patterns. I was wondering if i can let the rule check if the part is an multi-body part first?
Mark.Lancaster
@b_ruijter
Programming needs for Inventor should be asked in the Inventor customization forum.  https://forums.autodesk.com/t5/inventor-customization/bd-p/120
I will have the moderator relocate your posting there.
Mark Lancaster
mcgyvr
Not sure if there is a better way
oDoc = ThisApplication.ActiveDocument
oCount = oDoc.ComponentDefinition.SurfaceBodies.Count
If oCount > 1
	MessageBox.Show("Multi-Body", "Hey look")
WCrihfield
Here's a slighly different and equally simple way.
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
MsgBox("HasMultipleSolidBodies = " & oPDef.HasMultipleSolidBodies.ToString)
Wesley Crihfield
(Not an Autodesk Employee)
