Here's one way to do it.
I left a lot of the PDF Translator's options in place but commented out so you can set them how you want them.
Here's the iLogic code.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("This Rule '" & iLogicVb.RuleName & "' only works on Drawing Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
Exit Sub
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oPDFAddin As TranslatorAddIn
For Each oAddin As ApplicationAddIn In ThisApplication.ApplicationAddIns
If oAddin.DisplayName = "Translator: PDF" Then
oPDFAddin = oAddin
End If
Next
'The following lines are to define needed aspects of the Translator, so we can modify its options.
Dim oTO As TransientObjects = ThisApplication.TransientObjects
Dim oContext As TranslationContext = oTO.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oOptions As NameValueMap = oTO.CreateNameValueMap
Dim oDataMedium As DataMedium = oTO.CreateDataMedium
'The following If-Then statement defines the Options available, and their Values.
If oPDFAddin.HasSaveCopyAsOptions(oDDoc, oContext, oOptions) Then
oOptions.Value("Publish_All_Sheets") = 1 ' 0 = False, 1 = True
oOptions.Value("Launch_Viewer") = 1 ' 0 = False, 1 = True
oOptions.Value("Publish_Mode") = 62721 'This seems to be the norm for exporting a normal drawing. There may be another value for 3D PDF's.
'oOptions.Value("Enable_Measure") = 1
'oOptions.Value("Enable_Markups") = 1
'oOptions.Value("Output_Path") =
'oOptions.Value("Sheet_Metal_Flat_Pattern") = 0
'oOptions.Value("Sheet_Metal_Part") = 1
'oOptions.Value("Weldment_Symbol") = 0
'oOptions.Value("BOM_Parts_Only") = 1
'oOptions.Value("Instructions") = 0
'oOptions.Value("iAssembly_3D_Models") = 0
'oOptions.Value("iPart_3D_Models") = 0
'oOptions.Value("Publish_Mass_Props") = 1
'oOptions.Value("Publish_Screenshot") = 0
'oOptions.Value("Facet_Quality") = 69379
'oOptions.Value("Facet_Recompute_Tolerance") = 0.001
'oOptions.Value("Sheet_Color") = 0
'oOptions.Value("Custom_Begin_Sheet") = 1
'oOptions.Value("Custom_End_Sheet") = 4 (it is not confirmed that this line works)
oOptions.Value("All_Color_AS_Black") = 0 ' 0 = False, 1 = True
oOptions.Value("Vector_Resolution") = 4800 ' DPI
oOptions.Value("Remove_Line_Weights") = 0 ' 0 = False, 1 = True
'oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
'oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
'oOptions.Value("Print_Excluded_Sheets") = 0 ' 0 = False, 1 = True (DOESN'T SEEM TO BE WORKING YET)
End If
'Set the PDF file name
'oDataMedium.FileName = ThisDoc.Path & "\" & ThisDoc.FileName(False) & ".pdf"
Dim oDeskTopDir As String = System.Environment.GetFolderPath(System.Environment.SpecialFolder.DesktopDirectory)
Dim oFileName = IO.Path.GetFileNameWithoutExtension(oDDoc.FullFileName)
oDataMedium.FileName = oDeskTopDir & "\" & oFileName & ".pdf"
'Check to see if the PDF already exists, if it does, ask if you want to over write existing or not.
If System.IO.File.Exists(oDataMedium.FileName) = True Then
oAnswer = MsgBox("A PDF file with this name already exists." & vbCrLf &
"Do you want to over write it with this new one?",vbYesNo + vbQuestion + vbDefaultButton2, "PDF ALREADY EXISTS")
If oAnswer = vbNo Then Return
End If
'Publish PDF
oPDFAddin.SaveCopyAs(oDDoc, oContext, oOptions, oDataMedium)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
If you have time, please... Vote For My IDEAS 💡and Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
