iLogic Rule to preselect sheet metal style
bbrumfield
bbrumfield
Any ideas on how to use/create an iLogic Rule to preselect sheet metal style when creating a new sheet metal part (material & thickness) from sheet metal rule
dalton98
Just go into the sheet metal template and change it there.
bradeneuropeArthur
'' Dim a As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("SheetMetalSetBodyRuleStyleCtxCmd")
Dim a As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("SheetMetalStylesCmd")
a.Execute
you mean on create new from template you need to see this box:
Let the above rule on new:
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bbrumfield
Hi bradeneuropeArthur,
That was exactly what I was looking for
I was able to make this work:
a.Execute
