Ilogic Rule To Mark Textbox in sketch for Engraving
jeanB99VC
Message 1 of 14
jeanB99VC
Hello There,
Im having trouble getting my code right for Mark(ing) (the new function in 2023)  my filenameNumber, to engrave with the laser. The code is working partly, the mark can't be made and I don't know why.
Please see my code below and advise me what is going wrong. I also attached the IPT file which I used.
Thank You in Advance
The Error Message i get is:
Error on line 97 in rule: YY_Mark_Tekeningnummer, in document: 97221181-0000 - Markfunction for Engraving.ipt
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.ObjectCollection'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{6939FFDD-BA10-11D2-B779-0060B0F159EF}' failed due to the following error: Interface wordt niet ondersteund (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
The Code is:
Sub Main()
'This Is a Ilogic Rule To create a Mark From a textbox For engraving
'It is made with help from internet but NOT WORKING RIGHT !
'I'm getting the message :
'Error On line 90 in rule: YY_Mark_Tekeningnummer, In document: 97221181-0000 - Markfunctie Nummer Filename.ipt
'Unable To cast COM Object Of type 'System.__ComObject' to interface type 'Inventor.ObjectCollection'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{6939FFDD-BA10-11D2-B779-0060B0F159EF}' failed due to the following error: Interface wordt niet ondersteund (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
' PLEASE HELP
 '  a reference to the currently active document.
 ' This assumes that it is a part document.
	    Dim oPartDoc As PartDocument
	    oPartDoc = ThisApplication.ActiveDocument
		Dim oCompDef As PartComponentDefinition
		oCompDef = oPartDoc.ComponentDefinition
  ' Set a reference to the transient geometry object.
    Dim oTransGeom As TransientGeometry
    oTransGeom = ThisApplication.TransientGeometry
'================ Pasted to pick the face where the Mark has to come ============================
'Select Face and Edges to dimension sketch circles from
Dim oFrontFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Text On")
		    ' Create a new sketch on this face
			    oSketch = oCompDef.Sketches.AddWithOrientation(oFrontFace, _
			    oCompDef.WorkAxes.Item(1), True, True, oCompDef.WorkPoints(1))
		    ' Determine where in sketch space the point (0.5,0.5,0) is.
			    Dim oCorner As Point2d
			    oCorner = oSketch.ModelToSketchSpace(oTransGeom.CreatePoint(0.5, 0.5, 0))
' ===================== Create a Custom Parameter in Iproperties "Tekeningnummer"======================
		'Creating Custom IProperty with filenumber in it calling it Tekeningnummer
			iProperties.Value("Custom", "Tekeningnummer") = ThisDoc.FileName(False) 'false = without extension
			iProperties.Value("Custom", "Tekeningnummer") = (Left(ThisDoc.FileName(False),14))
		'Creating a UserParameter Where the Tekeningnummer value Is put In
		Dim PropValue As String = iProperties.Value("Custom", "Tekeningnummer")
		'updates the user-defined Text Parameter
		TagName = PropValue
'================================ Create a textbox in the Sketch to place the Iporp Tekeningnummer ====================
		'     Create Text With simple String As Input.  Since this doesn't use
		'     any Text Overrides, it will Default To the active Text Style.
			Dim oTG As TransientGeometry
		    oTG = ThisApplication.TransientGeometry
			Dim sText As String
		    sText = TagName
		    Dim oTextBox As TextBox
		    oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(1, 1), sText)
'==================== Creating an Objectcollection to be Marked ======================
    Dim oSketchObjects As ObjectCollection
    oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection
    ' Get all entities in the sketch
    Dim oSketchEntity As SketchEntity
    For Each oSketchEntity In oSketch.SketchEntities
        oSketchObjects.Add(oSketchEntity)
    Next
'==================== Creating the Mark on the textbox  ======================
    Dim oMarkFeatures As MarkFeatures
    oMarkFeatures = oCompDef.Features.MarkFeatures
    ' Get a mark style.
    Dim oMarkStyle As MarkStyle
    oMarkStyle = oPartDoc.MarkStyles.Item(1)
	' Create mark definition.
	Dim oMarkDef As MarkDefinition
	oMarkDef = oMarkFeatures.CreateMarkDefinition(oSketchEntity, oMarkStyle)
	' Create a mark feature.
	Dim oMark As MarkFeature
	oMark = oMarkFeatures.Add(oMarkDef)
End Sub
Replies (13)
Message 2 of 14
Michael.Navara
Quick tip (not tested):
Replace oSketchEntity with oSketchObjects in following line
oMarkDef = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle)
Message 3 of 14
jeanB99VC
Hello There,
I've tried this but it still doesn't work. I still get the same Error Message.
Hope to hear if you another solution, or anybody for that manner
Message 4 of 14
Michael.Navara
My quick answer solves your original question about "Unable to cast COM object of type ..." (Some other errors remain).
But unfortunately it looks like the TextBox is not supported by MarkFeature as valid input geometry in the API.
I try to create new one and also copy existing definition. Both works for MarkFeature with lines but neither works for textbox.
Message 5 of 14
jeanB99VC
Hello Michael,
Indeed the strange thing is that if you apply the MarkFeature in Inventor it works with the textbox but not through API/Ilogic.
I'v also tried to convert the textbox into geometry but I can't get the code right to do this.
Maybe you know the code to do this and then collect this geometry to mark?
Still I hope that somebody knows how to make the markfeature on a textbox trhough Ilogic/API because of the fact that it is possible in Inventor itself.
Message 6 of 14
johnsonshiue
Hi Jean,
I took a look at the rule. There are two places to be modified. One is the oSketchObjects, which was pointed out earlier. The other one is about how to add Sketch Text to the Sketch Object. Sketch Text isn't considered a Sketch Entity in the API. It is called Text Box. The lines to be rewritten are Line 75 and below. Instead of using Sketch Entity to collect the Sketch Text geometry, TextBox is needed.
Dim oSketchText As TextBox
For Each oSketchText In oSketch.TextBoxes
oSketchObjects.Add(oSketchText)
Next
Attached is a copy of the working rule, please take a look.
Many thanks!
Software Test Engineer
Message 7 of 14
WCrihfield
Just adding one additional tip in there, to add to what @johnsonshiue just contributed...
When declaring a variable for a TextBox object in iLogic, you should always declare it as 'Inventor.TextBox', instead of simply 'TextBox', because iLogic gets it confused with the System.Windows.Forms.TextBox object if you don't, which can cause problems/errors to happen in your code.
Wesley Crihfield
(Not an Autodesk Employee)
Message 8 of 14
jeanB99VC
Hi Shiue,
Thank you very much for your solution! 🙂
It works fine.
Now I can finetune it so I can determine the place on the face the Mark should be.
Again Many Thanks!
Message 9 of 14
jeanB99VC
Hi WCrihfield,
I have added your remark on de the Invenor.Textbox to the rule from Shiue !
Thank you very much for the help you all gave !
Message 10 of 14
CAD_CAM_MAN
@johnsonshiue
I am having difficulty implementing similar code successfully in an add-in I am writing. The code is mostly an exact copy of your attached file.
Everything seems to work as expected until the last line oMark = oMarkFeatures.Add(oMarkDef) is read.
when the aforementioned line is read the add-in just stops debugging. There is no exception thrown. It does not crash Inventor etc. After the debugging stops I am able to immediately go to the model and manually create a mark feature without issue on the textboxes in the sketch, the  MySketch object is accessing.
Any ideas what I may be missing here?
            Dim MySketch As PlanarSketch = BP.ECDef.Sketches.Item(MySketchIndex)
            Dim MyPCDef As PartComponentDefinition = BP.ECDef
            Dim MyDoc As PartDocument = BP.ECDoc
            oSketchObjects = g_IApp.TransientObjects.CreateObjectCollection
            For Each oSketchText In MySketch.TextBoxes
            Next
            oMarkFeatures = MyPCDef.Features.MarkFeatures
            ' Get a mark style.
            oMarkStyle = MyDoc.MarkStyles.Item(1)
Message 11 of 14
ctx400
I have the same problem, anyone with a solution?
Message 12 of 14
bbailey6E5PN
Hello, I am having trouble with this code. Everything works as it should but I cannot get the placement of the mark feature to change after editing values. Am I missing something? Any opinion would be helpful, thank you.
Message 13 of 14
bbailey6E5PN
Did you end up figuring out how to change the placement of the feature?
Message 14 of 14
jeanB99VC
Hello There,
What do you mean by changing the placement?
The placement is set by clicking the lines. You can change it afterwards by changing the sketch.
