VB.Net Eample - Create Pdf File From Drawing (idw or dwg)
isocam
isocam
Can anybody help?
Has anybody managed to create a VB.Net program that can automatically create a PDF file from an Inventor "idw" or "dwg" file?
If you have, please can you attach a sample in zip format?
Many thanks in advance!
Darren
BM_Ashraf
Check this Video
https://www.youtube.com/watch?v=lZwvoapamgo&t=5s
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Sub PDF()
Dim oDoc As DrawingDocument = g_inventorApplication.ActiveEditDocument
Dim oSuffix As String = System.IO.Path.GetExtension(oDoc.FullDocumentName)
Dim oPDF As String
oPDF = Replace(oDoc.FullDocumentName, oSuffix, ".pdf")
If System.IO.File.Exists(oPDF) Then
Dim Ask2 As Object
Ask2 = MsgBox("The document already exists in the selected path!" & vbLf & vbLf & oPDF & vbLf & vbLf & "Do you want to override it?", MsgBoxStyle.YesNo, "Existing Pdf Document")
If Ask2 = vbNo Then
 exit sub
On Error Resume Next
Call oDoc.SaveAs(oPDF, True)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
isocam
I have tried your code but the following line creates an error
Please can you tell me what is wrong?
Kind Regards
Darren
BM_Ashraf
Sorry , I missed this line
Public g_inventorApplication As Inventor.Application
it's usually default in Inventor template in Visual studio
____________________________________________________
Imports Inventor
Sub PDF()
Dim oPDF As String
Dim Ask2 As Object
If Ask2 = vbNo Then
 exit sub
End Sub
Blue Mech
