iLogic rule to mark parameter as exported
I am looking for an iLogic code to mark a specific user parameter in each part and subassembly to key, export, and set the "custom property type" under the equation column to be fractional instead of decimal with 1/32" precision in one all encompassing assembly (that way I don't have to run this code in each individual part, just once in the main assembly). The parameter is called PARTLENGTH and I have kind of a general code idea here:
'Dim oDoc As AssemblyDocument
Dim oDoc As PartDocument = ThisDoc.Document 'of : oDoc as AssemblyDocumment = ThisDoc.Document
'nummerieke parameter
Try
prop = oDoc.ComponentDefinition.Parameters.UserParameters.item ("PARTLENGTH")
Catch
End Try
param =Parameter.Param("PARTLENGTH")
param.ExposedAsProperty = True
'param.CustomPropertyFormat.Precision = kThreeDecimalPlacesPrecision
param.CustomPropertyFormat.ShowTrailingZeros = False
param.CustomPropertyFormat.ShowLeadingZeros = False
param.CustomPropertyFormat.ShowUnitsString = False
'param.CustomPropertyFormat.Units = "in"
How close is this rule to being correct? I'm afraid to run it
MechMachineMan
Make a test document and try er out!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Milan_Nosil
It works! Thank you very much 😉
Hi. I have the same issue for user parameter. Would u shere the script w/ me?
WCrihfield
@Anonymous
Are you looking for something like this?
Dim oDocType As DocumentTypeEnum = ThisApplication.ActiveDocumentType
Dim oParams As Parameters
If oDocType = DocumentTypeEnum.kPartDocumentObject Or _
	oDocType = DocumentTypeEnum.kAssemblyDocumentObject Then
	oParams = ThisApplication.ActiveDocument.ComponentDefinition.Parameters
ElseIf oDocType = DocumentTypeEnum.kDrawingDocumentObject Then
	oParams = ThisDrawing.Document.Parameters
Dim oUParams As UserParameters = oParams.UserParameters
Dim oUParam As UserParameter
Dim oParamName As String = "Param_Name"
'Dim oParamName As String = InputBox("Enter a parameter name.","","")
Dim oExists As Boolean 'false by default
For Each oUParam In oUParams
	If oUParam.Name = oName Then
		oExists = True
		oUParam.IsKey = True
		oUParam.ExposedAsProperty = True
		Dim oCPF As CustomPropertyFormat = oUParam.CustomPropertyFormat
		oCPF.PropertyType = Inventor.CustomPropertyTypeEnum.kNumberPropertyType
		oCPF.Units = Inventor.UnitsTypeEnum.kInchLengthUnits
		oCPF.Precision = Inventor.CustomPropertyPrecisionEnum.kEightDecimalPlacesPrecision
		'oCPF.Precision = Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
Next
If oExists = False Then
	MsgBox("That parameter was not found.",,"")
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you have time, please... Vote For My IDEAS 💡or you can Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
