iLogic rule to insert part parameters into dimension text in assembly drawing
I am trying to speed-up dimensioning of an assembly drawing (DWG) in Inventor using iLogic. The assembly contains parts which have parameters which I would like inserted into dimension text. I can achieve this manually using the Edit Dimension / Format Text dialogue boxes to select the part parameters and insert them into the assembly dimension text.
My iLogic rule can currently identify the part containing the parameters but when I attempt to write these to the dimension text, I receive an error message.
The part parameters are called “No_Risers” and “riser”. “partFileName” is the FullFileName of the Part Document containing these parameters.
Code Snippet
If oPart.ComponentDefinition.Material.Name = "Concrete" Then
partFileName = oPart.FullFileName
oDimensionText.FormattedText = "<Parameter Resolved = 'True'
ComponentIdentifier='" & partFileName & "' Name = 'No_Risers'
Precision = '0'></Parameter>" & " No. RISERS @ " & "<Parameter Name
= 'riser' Precision = '2'></Parameter>" & " = " &
"<DimensionValue/>"
End of Code
The line which gives me the error message is the oDimensionText line :
(I have split the long line of code so it reads better on the forum. It is one line in the iLogic rule)
I have tried many variations of the above, but cannot get it to work. I can successfully write the parameter values to the dimension text, but these do not update if the parameters update.
I’m using Inventor 2013 Pro
Any help would be gratefully received.
