iLogic rule to insert part parameters into dimension text in assembly drawing
Message 1 of 1
I am trying to speed-up dimensioning of an assembly drawing (DWG) in Inventor using iLogic. The assembly contains parts which have parameters which I would like inserted into dimension text. I can achieve this manually using the Edit Dimension / Format Text dialogue boxes to select the part parameters and insert them into the assembly dimension text.
My iLogic rule can currently identify the part containing the parameters but when I attempt to write these to the dimension text, I receive an error message.
The part parameters are called “No_Risers” and “riser”. “partFileName” is the FullFileName of the Part Document containing these parameters.
Code Snippet
If oPart.ComponentDefinition.Material.Name = "Concrete" Then
partFileName = oPart.FullFileName
End If
oDimensionText.FormattedText = "<Parameter Resolved = 'True'
ComponentIdentifier='" & partFileName & "' Name = 'No_Risers'
Precision = '0'></Parameter>" & " No. RISERS @ " & "<Parameter Name
= 'riser' Precision = '2'></Parameter>" & " = " &
"<DimensionValue/>"
End of Code
The line which gives me the error message is the oDimensionText line :
(I have split the long line of code so it reads better on the forum. It is one line in the iLogic rule)
I have tried many variations of the above, but cannot get it to work. I can successfully write the parameter values to the dimension text, but these do not update if the parameters update.
I’m using Inventor 2013 Pro
Any help would be gratefully received.
Replies (0)
