How to detect if ctrl is pressed in the OnRadialMarkerMenu event?
psaarloos
psaarloos
I am trying to create a RedialMarkerMenu that needs to be shown in several environments. Since I don't want to change the default radialmarker menu's I want to add the new one that shows up when the CTRL button is pressed. The Inventor Customize UI has the option to set the 'Sub-Environment' for a radial marker menu. How can I achieve this by API?
Pim
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
philippe.leefsma
Hi Pim,
Unfortunately I don't think the API provide a built-in feature to manage that. It would be relatively straightforward to determine if CTRL is pressed relying on .Net API, hence act accordingly when you happend your controls to the radial menu:
http://stackoverflow.com/questions/1100285/how-to-detect-the-currently-pressed-key
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
psaarloos
Hi Philippe,
That works! Thanks! The code below did the tricj:
if (Control.ModifierKeys == Keys.Control)
// Do Stuff
Pim Saarloos
Product Manager
