Find Drawing View Orientation ilogic
johnster100
johnster100
I've written some simple code which sets the scale of all the views in a drawing. However, I would like it skip any views which are iso, as we always have a small iso view in the corner of our drawings. The scale of these is much less that scale of the main views.
Is it possible to do this this in ilogic?
ie.
 For Each oView As DrawingView In oSheet.DrawingViews
      if oView.ORIENTATION = iso then
            'next
     else
          oView.Scale = 1 / var
     end if
next
I have not been able to find an orientation object in the DrawingView object.
thanks,
John
LukeDavenport
Using the DrawingView.Camera.ViewOrientationType might be good enough for you. The below code works fine for me - the only problem is if your ISO view is not a base view (its a projected or auxiliary view perhaps) then it won't be recognised as ISO in the ViewOrientationType Enum, just as 'Arbitrary'.
Sub Main Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument For Each oView As DrawingView In oDrawDoc.Sheets.Item(1).DrawingViews 'Define camera
Dim cam As Camera = oView.Camera If Not oView.Camera.ViewOrientationType = 10762 AndAlso _ Not oView.Camera.ViewOrientationType = 10761 AndAlso _ Not oView.Camera.ViewOrientationType = 10760 AndAlso _ Not oView.Camera.ViewOrientationType = 10759 Then MessageBox.Show("Not an ISO base view", "Title") oView.Scale = 0.1 End If Next End Sub
johnster100
worked a charm.
thanks,
John
LukeDavenport
My pleasure!
lucas_lacerda_proj
In my case, it´s a Projected view, how can I proceed?
Like @LukeDavenport said, this way it won´t work.
Curtis_Waguespack
Hi @lucas_lacerda_proj ,
You can use something like this to check the ViewType.
I hope this helps.
Curtis
	For Each oView As DrawingView In oDrawDoc.ActiveSheet.DrawingViews
		If Not oView.ViewType = DrawingViewTypeEnum.kProjectedDrawingViewType
			'do some stuff with non-projected views
			MsgBox(oView.Name & " is NOT a projected view.",, "iLogic")
	Next
		If oView.Viewtype = DrawingViewTypeEnum.kProjectedDrawingViewType
			'do some stuff with projected views
			MsgBox(oView.Name & " is a projected view.",, "iLogic")
	Next
Curtis_Waguespack
DrawingViewTypeEnum Enumerator
Description
Drawing View Type.
Methods
Name Value Description
kAssociativeDraftDrawingViewType 10506 View is an associative draft one.
kAuxiliaryDrawingViewType 10499 View is an auxiliary one.
kCustomDrawingViewType 10498 View with customized camera setting.
kDefaultDrawingViewType 10497 Specifies the default View. The more strongly typed value is returned in a query.
kDetailDrawingViewType 10502 View is a detail of a portion of the document contents.
kDraftDrawingViewType 10505 View is a draft one.
kOLEAttachmentDrawingViewType 10500 View is an OLE attachment.
kOverlayDrawingViewType 10507 View is an overlay one.
kProjectedDrawingViewType 10504 View is a projected one.
kSectionDrawingViewType 10503 View is a section.
kStandardDrawingViewType 10501 View with the camera set to one of the standard orthogonal views (Top, Iso, etc.).
