iLogic Rule to Generate All iAssembly members
lodgera
lodgera
I'm trying to write a simple rule to generate all iAssy members.  Can someone tell me what's wrong here?  Whenever I run this Inventor just crashes . . .
Dim factory As iAssemblyFactory = ThisAssembly.Document.ComponentDefinition.iAssemblyFactory
Dim rows As iAssemblyTableRows = factory.TableRows
Dim row As iAssemblyTableRow
For Each row In rows
factory.CreateMember(row)
Next
A.Acheson
Any errors in the members? The rule works  fine in 2020. Does it generate any error messages? What inventor version are you using?
Regards
Alan
fidel.makatiaD5W7V
Hi @lodgera check this link for a VBA code that implements iAssembly occurence  in Inventor 2022.
Inventor 2022 Help | Adding iAssembly occurrences | Autodesk
Let me know in case of any questions
Fidel Makatia
Developer Advocate
href=https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-0BD48573-7193-4285-87B7-6727555D053E rel= "noopener noreferrer">Inventor 2022 Documentation |
lodgera
I'm running 2021.  In the file I was using there were lots of errors so let's forget about that one for now.  I'm now running in a 7 member iAssembly with zero errors.  When I run the rule, it seems to generate members randomly.  The member files already exist on my machine, but my understanding is CreateMember should overwrite/replace any existing file for that member.  On the file I'm in now, the first time I ran it, it created/updated one member file in the middle of the table (member 4 out of 7).  Subsequent attempts to run the rule don't seem to do anything at all.
A.Acheson
Yes there is consistent issues with running generate members by code and manually. Try perform a manage  rebuild all and save then generate members. If that still doesn't work then change an item in the table and then change it back. Some users add an other column just for this update to actually get an update to happen.
And to top it all I have had files that only a manual generate worked.
Hope that helps.
Regards
Alan
lodgera
I appreciate the input thus far.  I'm trying to figure out some solution to the fact that Inventor wants to 'initial save' iAssembly members for seemingly no reason.  I had read somewhere in this forum that the code-initiated member generation just auto-saves and doesn't give you the prompt you have to click.  But at this point that doesn't seem to be much help given the hit-or-miss the code is.  Any other ideas I'd love to hear them!
