Cannot Pull Prompted Entry with VBA
MichaelTV334
MichaelTV334
Visual Studio 2019. Inventor 2022.
I'm trying to pull <TITLE> from a titleblock. Some of my titleblocks are prompted entry, and others pull from a part. In either case, I see <TITLE> when looking at the titleblock.
I cannot get my code to read the prompted entry field, but if a sheet doesn't use a prompted entry for <TITLE> then it will read the value.
When I have the values input into excel, the prompted entry values are blank, but the auto-read values appear.
Here is the portion of my code that reads the value.
For Each otextbox In colTextBoxes
   If otextbox.Text = "<TITLE>" Or otextbox.Text = "PROJECT_TITLE" Then
      oDrawingTitle = otextbox
      Continue For
Next
If I put in a
Or otextbox.Text = "TITLE" Then
after the other conditions.
When I do this without the <> before TITLE and the blank values in excel become TITLE .
Does anyone have an idea of how to read prompted entry values?
A.Acheson
From reading and testing the post from here
The below sample should work.
Public Sub TitleBlock()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oTitle As Inventor.TitleBlock
    Set oTitle = oDoc.ActiveSheet.TitleBlock
    Dim oTextBox As TextBox
    Dim oTextBoxes As TextBoxes
    Dim sData As String
    Set oTextBoxes = oTitle.Definition.Sketch.TextBoxes
    For Each oTextBox In oTextBoxes
      sData = oTitle.GetResultText(oTextBox)
      If oTextBox.text = "COMPANY" Then
      	Company = sData
      	MsgBox (Company)
    Next
End Sub
Regards
Alan
WCrihfield
Handling prompted entries by code can get complicated.  How complicated and which route to take depends a lot on how you set everything up.  Here are a few more links you might want to check out.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/grab-view-title-place-it-into-a-prompte...
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/copy-prompted-entries-to-drawing-custom...
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/editing-prompted-entry-values-with-ilog...
Wesley Crihfield
(Not an Autodesk Employee)
