iLogic rule to delete a pattern and its occurrences in an assembly
Couple of years ago, someone helped me for following code to delete a pattern and its occurrences in an assembly. It worked fine before.
SyntaxEditor Code Snippet
    Dim oDoc As Document
    oDoc = ThisDoc.Document
    Dim oComp As ComponentOccurrence
    Dim oComps As ComponentOccurrences
    oComps = oDoc.ComponentDefinition.Occurrences
    For Each oComp In oComps
        If Component.IsActive(oComp.Name) = False Then
          oComp.Delete
        End If
    Next
But recently, I found it does not work now. The statement "oComp.Delete" has following error.
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ComponentOccurrence.Delete()
at LmiRuleScript.deleteComponents()
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Does anyone know what it is happened? And I can I fix it?
I do not know how many pattern in the assembly and do not know their names also. I need delete all suppressed occurrences and patterns.
If you could provide modified code, it will be much appreciated.
MechMachineMan
This should work.
Sub Main()
	Dim oDoc as Document
	Dim oAsmCD As AssemblyComponentDefinition
	oAsmCD = oDoc.ComponentDefinition
	Dim oObjToDelete As Object
	On Error Resume Next
	Dim oOcc As ComponentOccurrence
	For Each oOcc in oAsmCD.Occurrences
		If oOcc.Suppressed = True
			oObjToDelete = GetAssyLevelItemToDelete(oOcc)
			oObjToDelete.Delete
			oOcc.Delete
		End If
	Next
End Sub
Function GetAssyLevelItemToDelete(oOcc As Object) As Object
	If oOcc.IsPatternElement
		oOcc = oOcc.PatternElement.Parent
		oOcc = GetAssyLevelItemToDelete(oOcc)
	End If
	Return oOcc
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Great!
Thanks lot.
idealogicERZYZ
Hello
Is it possible to put "My property - Title - File name" in the occurence? So that you can update it when you open the file and when saving the file.
E
filippo.costantin3HZMT
Hi I have the same problem, but I need to delete only the occurrences.
How can I do that?
