iLogic Rule to Automatically Bring in all Flat-Pattern Parts into Drawing
I'm hoping someone can help me. Do I need some sort of iLogic rule if want to automate the process of bringing in all associated sheet metal parts of a specific assembly, i.e. If I were to bring in an assembly on the first page, can all the individual sheet metal parts (flat-pattern views) be automatically brought in on the adjacent pages? If so, does such an ilogic rule already exist out there?
Thank-you.
MechMachineMan
Yes. In fact, I have written similar routines in the past.
If you can do something through the UI, you can almost certainly program it to be done via VBA/Vb.net through Inventors API.
There are probably rules already out there on the forums, but I'm sure as heck not gonna sift through to find them for you. Good try and good luck! Smiley Very Happy
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
