iLogic rule: save idw as pdf in user specified folder.
I have a rule which automatically saves an idw as a pdf file with the drawing's revision number as a post-fix.
Unfortunately, I've only managed to get the pdf automatically saved in a predefined location.
What I am looking for is a code which enables a pop-up window which will ask the user where pdf file shall be stored, similar to a save-copy-as window.
Can anyone help me with this?
Cheers,
Lars
ing_manuellucena
Hi Boijens!
This is what your looking for
http://inventortrenches.blogspot.com/2011/07/ilogic-to-save-pdf-files-to-new.html
Please if you fix your issue accept as solution
See you!
Ing. Manuel Lucena
Hi Manuel!
Thank you for your reply. The code you referred to is ALMOST what I am looking for. However, the referred to code automatically copies a pdf file into a specific location. What I am looking for is a window that pops up after running the rule, which allows to user to browse to a folder location where he or she wants to store the pdf.
L
MechMachineMan
Look up "FolderDialog".
There is a save option within the function that makes the window mimic the save as functionality.
Note this function/feature will just return a string from the selection window, and you will have to pass that string to your Save method.
ie; see this blog post:
http://inventortrenches.blogspot.ca/2012/10/ilogic-adding-save-as-dialog-box.html
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
