iLogic rule runs in .iam but will flag an error if drawing file is open
I have a rule which inserts the 'z' value of the bounding box for each part in an assembly into the iproperty value 'vendor'
this works fine when I run it in the assembly level, but if I happen to have a drawing file open, it will reprt an error.
I cant understand why......any help?
Version:1.0 StartHTML:00000145 EndHTML:00004951 StartFragment:00000294 EndFragment:00004919 StartSelection:00000294 EndSelection:00000294SyntaxEditor Code Snippet
'Find all parts in this assembly that contain parameter name G_L
'Convert the boundary box z dimension into an iProperty
fmgr = ThisApplication.FileManager
For Each file In fmgr.files
    doc = ThisApplication.Documents.ItemByName (file.fullfileName)
    compdef = doc.ComponentDefinition
    If (doc.documenttype = 12291) Then 'Only do this for assembly or subassembly
        For Each occ In compdef.Occurrences
            If (occ.definition.type = 83886592) Then 'Only do this for part
                Try     'Look for existance of G_L parameter
                    TempG_L = Parameter(occ.Name, "G_L")
                Catch   'Part does not contain G_L
                    GoTo skipThisPart
                End Try 'Found a file containing G_L
		templen = Round(10*(occ.definition.RangeBox.MaxPoint.Z - occ.definition.RangeBox.MinPoint.Z),1)
		templen = Ceil(templen) 'Rounds the result to next whole number
                'Push this number value into an unused iProperty
                iProperties.Value(occ.Name, "Project", "Vendor") = templen
            skipThisPart:
        Next occ
Next File
InventorVb.DocumentUpdate() 'Update the model
AlexFielder
This is happening because as the error message states there is no ComponentDefinition on the DrawingDocument object:
2018-08-02 11_12_52-Autodesk Inventor Professional 2019 - [Frame Example.iam].png
One way to fix this is to change your rule like so:
For Each file In fmgr.Files
	Try
    doc = ThisApplication.Documents.ItemByName (File.fullfileName)
                    GoTo skipThisPart
            skipThisPart:
        Next occ
	Catch
		Continue For
	End Try
Next File
chandra.shekar.g
Autodesk Support
Autodesk Support
Good catch @AlexFielder,
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
