iLogic Checking on which plane sketch is defined.
Hi Guys,
I'm looking for the solution of following problem:
I'd like to use iLogic rule to check if a sketch (There will be only one used for part creation) was definied on XY plane or not.
I need this information for further part area calculation (with Measure.ExtentsWidth  and Measure.ExtentsLength
function).
Right now I have a piece of code which dosen't work:
SyntaxEditor Code Snippet
On Error Resume Next
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch
oSketch = oDef.Sketches.Item(1)
Dim xyPlane As Inventor.WorkPlane
xyPlane = oDef.WorkPlanes.Item(3)
If oSketch.WorkPlanes <> xyPlane Then
MessageBox.Show("Sketch needs to be definied on XY plane!", "iLogic")
Exit Sub
Thanks in advance for any help.
Best Regards
Tomek
Curtis_Waguespack
Hi @Anonymous
Try something like this example.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Try
	If oSketch.PlanarEntity.Name <> "XY Plane" Then
		MessageBox.Show _
Catch
	'catch error when no sketch is found
End Try
Hi Curtis,
It looks like the rule works fine right now.
Thanks a lot for help.
Best Regards
Tomek
