Ilogic rule reset all BOM structure to Normal
morrenengineering
morrenengineering
hi, I am working with Inventor Pro 2021. I want to make different part lists with different levels.
1. Rule1 - reset all parts and assembly 's in the main assembly to "normal"
2. Rule2 - set all sub assembly' s with containing a L (netherlands for the first letter of Lassen (welding)) to Inseperatable.
Maybe it could be a short code.
bhavik4244
@morrenengineering
This could help you.
For normal BOM:
'Rule:1
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'set BOM Structure to Normal
Try
oOccurrence.BOMStructure = BOMStructureEnum.kNormalBOMStructure
Catch
End Try
For Inseperable BOM:
'Rule:2
'set BOM Structure as Inseparable
Try
oOccurrence.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
Catch
End Try
Bhavik Suthar
morrenengineering
@bhavik4244
I tried, but it gave a compile error, line 6, For must end with an Next instruction.
Excuses that I am not a real programmer.
bhavik4244
@morrenengineering
you're right just place "Next" at the end of the rule, I missed it while copying from my system 🙂
Bhavik Suthar
morrenengineering
@bhavik4244
The rules changed nothing so far as I can see. the intention was to check all compositions in the entire tree and set them all to "Normal". The rule does not return an error message, but it seems that it does not go all the way down the entire tree.
I have another ilogic rule that makes a STP file out of the whole tree. I want to do that at the same way, each IAM setting the BOM structure to "Normal"
morrenengineering
The first rule now is running perfectl
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the referenced models
For Each oRefDoc In oRefDocs
	Dim oCurFile As Document
	oCurFile = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
    oCurFileName = oCurFile.FullFileName
    'defines backslash As the subdirectory separator
    Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
    	Try
			oCurFile.ComponentDefinition.BOMStructure = BOMStructureEnum.kNormalBOMStructure
    	Catch
    	End Try
	oCurFile.Close
	Next
morrenengineering
The second rule for "inseperatable" when a filename containt "L" is nog working yet. Can anyone help me. The code i have now stands below. The problem is
If oCurFile.Name.Contains("L") Then
The complete file
    	Try
			oCurFile.ComponentDefinition.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
		End If
    	Catch
        	'MessageBox.Show("Error processing " & oCurFileName, "ilogic")
    	End Try
	oCurFile.Close
	Next
