Here is something that I think should do what you want.
The top several lines of this VBA macro code are specifying the names of the 'target' VBAProject, Component (module), & Member (macro). You will likely have to change these names to match your situation. The project name is reffering to its 'DisplayName', and is usually something like "ApplicationProject" or "DocumentProject", so if you are looking for an application project among many application projects, you may have to dig deeper to find the right one (same deal with document projects). The component name is generally the name of the module. And the member name is generally the name of the macro. The macro's name is the name of the main procedure within the module. I have included comments about them within the code.
The next section gets the Inventor.Application object, and sets it to a variable, for use later in the code (it should work in Inventor and in Excel, as long as you have the right References turned on).
Then it starts attempting to get the actual project, component, & member objects. I have set-up some fail-safe checks in there to catch when it isn't found. And I have included some feedback MsgBox's for when they are found, for now, but you will likely want to comment those out once you get it set-up and working, because they can get annoying. Once it gets the member object (macro), it can execute it. I have included some comments about that step too. Basically, if your macro is set-up as a Function, you can create a variable just ahead of executing the macro, and put that variable in the () after Execute, to hold the returned value/object from the macro.
Here's the code:
Sub RunOtherMacro()
Dim oTargetProjectName As String
oTargetProjectName = "ApplicationProject"
Dim oTargetProjectFFN As String
oTargetProjectFFN = "C:\Temp\Target VBA Project.ivb"
Dim oTargetComponentName As String '(name of the Module itself)
oTargetComponentName = "Export_to_PDF"
Dim oTargetMacroName As String '(name used in first/main public method within the Module)
oTargetMacroName = "Export_to_PDF"
Dim oInvApp As Inventor.Application
On Error Resume Next
Set oInvApp = GetObject(, "Inventor.Application")
If Err.number <> 0 Then
Set oInvApp = CreateObject("Inventor.Application")
If oInvApp Is Nothing Then Exit Sub Else Err.Clear
On Error GoTo 0
'Dim oInvVBA As Inventor.VbaApplication
'Set oInvVBA = oInvApp.VbaApplication
Dim oInvVBAProjects As Inventor.InventorVBAProjects
Set oInvVBAProjects = oInvApp.VBAProjects
'get the target VBA project (can't get it by Item("Name"))
Dim oProject As Inventor.InventorVBAProject
Dim oTargetProject As Inventor.InventorVBAProject
For Each oProject In oInvVBAProjects
'Call MsgBox("oProject.Name = " & oProject.Name, , "")
If oProject.Name = oTargetProjectName Then
Set oTargetProject = oProject
Exit For
Next
If oTargetProject Is Nothing Then
Call MsgBox("oTargetProject Is Nothing, so it was not found. Try another project name. Exiting.", , "")
Exit Sub
'Call oInvVBAProjects.Open(oTargetProjectFFN)
'get the target module
Dim oTargetModule As Inventor.InventorVBAComponent
Set oTargetModule = oTargetProject.InventorVBAComponents.Item(oTargetComponentName)
Call MsgBox("Error while attempting to get target component directly by Item(Name). Exiting." & vbCrLf & _
"Err.Number = " & CStr(Err.number) & vbCrLf & _
"Err.Description = " & Err.Description, , "")
Exit Sub
If oTargetModule Is Nothing Then
Call MsgBox("oTargetModule Is Nothing, so it was not found. Try another component/module name. Exiting.", , "")
Exit Sub
Else
Call MsgBox("oTargetModule was found!", , "")
On Error GoTo 0
'Get the target Macro
Dim oTargetMacro As Inventor.InventorVBAMember '(the Macro - main/top routine name within the Module)
Set oTargetMacro = oTargetModule.InventorVBAMembers.Item(oTargetMacroName)
Call MsgBox("Error while attempting to get target Member (Macro) directly by Item(Name). Exiting." & vbCrLf & _
Exit Sub
If oTargetMacro Is Nothing Then
Call MsgBox("oTargetMacro Is Nothing, so it was not found. Try another component/module name. Exiting.", , "")
Exit Sub
Else
Call MsgBox("oTargetMacro was found!", , "")
On Error GoTo 0
'If the Macro you are calling is a Function,
'you can create an Object variable here and supply it within () at the end of the Execute call
'to capture its return value (It is Optional)
'Dim oReturned As Object
'Call oTargetMacro.Execute(oReturned)
Set oInvApp = Nothing
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you have time, please... Vote For My IDEAS 💡or you can Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
